DelSolFreak Posted April 28, 2008 Share Posted April 28, 2008 scale of 1-5, 1 being the easiest and 5 the hardest, how difficult is it to remove the worn out stock suspension bushings and install polyurathane ones? Link to comment Share on other sites More sharing options...
Hatch92 Posted April 28, 2008 Share Posted April 28, 2008 i'd give it a 3 Link to comment Share on other sites More sharing options...
DelSolFreak Posted April 28, 2008 Author Share Posted April 28, 2008 does the haynes manual walk you through it or is it pretty much, disassemble, knock out old, press in new, reassmeble? Link to comment Share on other sites More sharing options...
Xeryon Posted April 28, 2008 Share Posted April 28, 2008 you got it: just remove and replace however you can do it. removal of each bushing is a little different. some just pop out, some are formed and have to be cut, torched and melted out, several have metal inner and outersleeves you have to reuse and a few come with new sleeves. a press of some variety would be required, if you are handy like I am I rigged a threaded shaft onto a couple old pistons to press in a couple of the larger ones, but a cheap press would be very useful, or access to a shop with a large one too. that and lots of lube! Link to comment Share on other sites More sharing options...
DelSolFreak Posted April 29, 2008 Author Share Posted April 29, 2008 would a 8" x 1/2" faced vice work? Link to comment Share on other sites More sharing options...
Xeryon Posted April 29, 2008 Share Posted April 29, 2008 don't see why not as long as you take your time and don't try to rush it - wouldn't want you to hurt yourself with all the improvising and such. Link to comment Share on other sites More sharing options...
