Kastigir Posted April 26, 2008 Share Posted April 26, 2008 Will these, fit ? They are 4x100 wheels, but there is no mention of their offset. Link to comment Share on other sites More sharing options...
Nancy Posted April 26, 2008 Share Posted April 26, 2008 as long as the offset is anywhere from +50 to +38, youre in business. ive used wheels with a +38 offset on my honda and it sits perfectly flush with the fender. im pretty sure that celica will be about the same. Link to comment Share on other sites More sharing options...
Kastigir Posted April 26, 2008 Author Share Posted April 26, 2008 Did a little more searching, and here is what I got. "ROTA Wheels GT3 15x7 (4x100+40mm, 67.1 Hub)" +40mm is good, what does the 67.1 hub mean? Link to comment Share on other sites More sharing options...
Kastigir Posted May 1, 2008 Author Share Posted May 1, 2008 Ok, I understand what offset is, but which would be better for a 91 Celica ST? +40 or +45mm? Link to comment Share on other sites More sharing options...
Ben. Posted May 1, 2008 Share Posted May 1, 2008 How much do you want the wheel to dip inward? The closer the number is to 0, the more of an inward dish it'll have. Link to comment Share on other sites More sharing options...
Kastigir Posted May 1, 2008 Author Share Posted May 1, 2008 I'm wanting to buy 15X6.5s. I'll need that rubber to fit under the fender. The higher the number, the more tuck correct? Link to comment Share on other sites More sharing options...
Joe W Posted May 1, 2008 Share Posted May 1, 2008 Did a little more searching, and here is what I got. "ROTA Wheels GT3 15x7 (4x100+40mm, 67.1 Hub)" +40mm is good, what does the 67.1 hub mean? The 67.1 is the hub diameter in millimeters. Offset Calc This should help give you a better idea of what to expect with different rim sizes and offsets. Link to comment Share on other sites More sharing options...
Kastigir Posted May 2, 2008 Author Share Posted May 2, 2008 The 67.1 is the hub diameter in millimeters.Offset Calc This should help give you a better idea of what to expect with different rim sizes and offsets. That tool is nice, but it doesn't help me much as I don't know the measurements of my current(stock) wheels. To get 15x6.5 wheels, with rubber under my fenders, is +40 or 45 better? I'm thinking +45. Oh, and I think I've decided on these. Link to comment Share on other sites More sharing options...
