92civichatch Posted April 13, 2008 Share Posted April 13, 2008 Just dropped a D16Z6 in my 92 hatch runs great...vtec works and everything just i don't have any low end torque. i installed a header on the it but i don't think that is it, i also eliminated the caytalic converter too, i turned the distributor all the way to the right it seemed to help, but its idling to high when i did it. if anyone has any suggestions it would help. Link to comment Share on other sites More sharing options...
airjordan223 Posted April 13, 2008 Share Posted April 13, 2008 the motor has no torque to begin with. welcome to the honda world Link to comment Share on other sites More sharing options...
92civichatch Posted April 13, 2008 Author Share Posted April 13, 2008 i'm gonna bring the d-series back!!! i'm gonna build it up and start blowing the doors off some of these b-series engines. Link to comment Share on other sites More sharing options...
airjordan223 Posted April 13, 2008 Share Posted April 13, 2008 booooooooooooooooooooooooooooooooooooooooooooost Link to comment Share on other sites More sharing options...
alex37211 Posted April 13, 2008 Share Posted April 13, 2008 you say it has no torque...in comparison with what? If it has less than the d15b7, then you have a problem. If it is your first experience with the d-series, it may have all the torque that it should. (it IS a 1.6L) Now that cat elimination may be causing some loss of needed back pressure if there aren't any mods to the engine. That motor was originally built with the cat in mind. Link to comment Share on other sites More sharing options...
Hatch92 Posted April 13, 2008 Share Posted April 13, 2008 spin the distributor back to normal. what kind of header do you have on it 4-2-1 or 4-1? also how do you plan on beatting the b-series mtoors, what do you plan to get done to it? Link to comment Share on other sites More sharing options...
SifreRacingtechs#2 Posted April 13, 2008 Share Posted April 13, 2008 well they might not have that much hp but go to youtube.com and look for sifre racing, and you will see what a D series motor could do to a turbo 2.0 and to alot more. Link to comment Share on other sites More sharing options...
92civichatch Posted April 14, 2008 Author Share Posted April 14, 2008 I put a 4-2-1 header on it, i plan on driving around with it for about a year then i'm taking back out and changing the crank, rods, pistions, and sleeving the block. and hopefully porting and polishing the head, and try running about 20psi of boost on it. i was wondering if it can take a 100 shot of nitrous stock??? Link to comment Share on other sites More sharing options...
