CivicSiR7 Posted June 4, 2003 Share Posted June 4, 2003 I purchased a 93 Si from an old couple. After a few months of having it, it didn't crank one day. I thought it was not having power so I jump start it and it didn't start. So next I thought it was the starter. Replaced it with one off my other civic I had. It still didn't work. I doubled check even triple check everything from the ECU codes (which there was no codes throwing at all), ground wires, wires to starter, fuses in engine bay, and in the car. Car still won't crank! AHHH! Hurting my head just thinking about it. I even tried to jump start it. But the odd thing is what my dad told me to do is, he told me to push start it. It worked, but when I shut the car off and try to crank it, it did the same thing NOTHING. But while I was driving around the block, it kinda sputtered like it wanted to shut off. Have any of you fellas ran into something like this? Link to comment Share on other sites More sharing options...
Blinker74 Posted June 4, 2003 Share Posted June 4, 2003 I would probably check your fuel delivery. If it's not cranking at all, it might be an electrical problem in the ignition switch itself or somewhere between the battery and the starter. Is the car turning over? Sounds like it wants to start, but won't. Link to comment Share on other sites More sharing options...
nosaj81_2000 Posted June 5, 2003 Share Posted June 5, 2003 also check your fuel pump and filters alot of times it could be just something easy like that when the sputters like you said. in one of my old cars that i used to have did the same thing. turned out it was just the fuel pump. Link to comment Share on other sites More sharing options...
JDM Jackass2 Posted June 5, 2003 Share Posted June 5, 2003 wow, you guys were helpful. even a 5 year old should know his problem has nothing to do with fuel. not the pump, filters, or delivery. push start the car, drive it to the mechanic, have them scan the system. Link to comment Share on other sites More sharing options...
Trepid Posted June 5, 2003 Share Posted June 5, 2003 if you let it idle does it die? do your dash lights come on when you have the key in it? Does the motor try to crank at all when you are turning the key? Link to comment Share on other sites More sharing options...
JDM Jackass2 Posted June 6, 2003 Share Posted June 6, 2003 it didn't crank one day Car still won't crank! when I shut the car off and try to crank it, it did the same thing NOTHING i think we can conclude his car wont crank. Link to comment Share on other sites More sharing options...
HyPe Posted June 6, 2003 Share Posted June 6, 2003 crank = bad drugs = bad Well i've never had your problem but u've alrdy checked everything u kno of to check, so the next thing is to call a honda dealer and see if they can give u some things to check over the phone. If still no work, then u're gonna hav to take it to a shop, either push start or tow, careful since u said it was sputtering.. Link to comment Share on other sites More sharing options...
importfan Posted June 24, 2003 Share Posted June 24, 2003 i ran into this problem with my 2000 civic. i was driving down the road and i heard a loud pop and my car just shut off. it wouldnt start or turn over. i took it to honda and it was the distributor coil. hope it helps Link to comment Share on other sites More sharing options...
geronimo502 Posted August 22, 2003 Share Posted August 22, 2003 If it turns over but won't crank, think about the Main Relay. Link to comment Share on other sites More sharing options...
optional187 Posted August 22, 2003 Share Posted August 22, 2003 If it turns over but won't crank, think about the Main Relay. think about looking at post dates Link to comment Share on other sites More sharing options...
civi93ex Posted August 22, 2003 Share Posted August 22, 2003 arent turning over and cranking the same thing, if it wont crank at all then its electrical, get an electrical tester and test all the wires from the ignition to the starter and if it is sputtering when it runs it could be fuel, but most likely its a loose wire somewhere thats bouncing around as your driving Link to comment Share on other sites More sharing options...
joecollins2 Posted August 22, 2003 Share Posted August 22, 2003 Hey buddy, he probably doesn't even have this damn car anymore man! That was 2 months ago!! Link to comment Share on other sites More sharing options...
