Currpt_God Posted February 27, 2008 Share Posted February 27, 2008 so i think my fuel pump is going out...... it starts to studder around 3500rpm at about 60mph and thats the only thing i can think of.... but to my question..... the engine is pretty stock right now other then some bolt ofs but im planning on building it here in the next 2 months but not sure which way im going still n/a or boost so.... should i go with a stock fuel pump or upgraded? Quote Link to comment Share on other sites More sharing options...
James Matteu Posted February 27, 2008 Share Posted February 27, 2008 Lemme just say this, the fuel pump don't care what rpm your at, it fails when it wants to fail. If you have some failure that is consistant as you implied in your OP, then you may be looking at a compound problem or something else altogether. Quote Link to comment Share on other sites More sharing options...
Currpt_God Posted February 27, 2008 Author Share Posted February 27, 2008 one of the local shops said it might be the distributer?............ would that happen if the distributer was going out? Quote Link to comment Share on other sites More sharing options...
delsol209 Posted February 27, 2008 Share Posted February 27, 2008 yup^ Quote Link to comment Share on other sites More sharing options...
dcletten Posted February 29, 2008 Share Posted February 29, 2008 yup^ x2 Quote Link to comment Share on other sites More sharing options...
Hatch92 Posted March 1, 2008 Share Posted March 1, 2008 whens the last tune up you had done on it? it sould be a bad set of plugs and wires. Quote Link to comment Share on other sites More sharing options...
Currpt_God Posted March 1, 2008 Author Share Posted March 1, 2008 ya i just did a full tune up about 7k miles ago and i pulled all the plugs and stuff to check them and everything was ok Quote Link to comment Share on other sites More sharing options...
Hatch92 Posted March 1, 2008 Share Posted March 1, 2008 i'd pull them and make sure they aren't fouled out Quote Link to comment Share on other sites More sharing options...
Currpt_God Posted March 2, 2008 Author Share Posted March 2, 2008 i pulled them all and everything is ok....... im running the NGK iridium Quote Link to comment Share on other sites More sharing options...
rocknskulls Posted March 2, 2008 Share Posted March 2, 2008 check your fuel filter? that could affect it i doubt thats it but its a cheap fix Quote Link to comment Share on other sites More sharing options...
