..SSR.. Posted February 20, 2008 Share Posted February 20, 2008 Prices do NOT include shipping. No lowballs. Pay with paypal (add 3%) or MO (USPS only). D17A1 head, no valve cover, what you see attached to it in the pic is what you get. $75 D17A1 water pump $5 D17A1 alternator bracket/mount $10 D17A1 breather chamber cover $2 D17A1 knock sensor $5 D17A1 oil pressure sensor $5 87 CRX Si CVCC OEM Honda exhaust gaskets never opened (2) 18110-PEO-010 $3/each Weber DGAV 32/36 on a 87 CRX Si CVCC ported IM. Carb comes with everything in pic except the exhaust gaskets. $200 OEM Honda hub never opened 42200-SD2-008 (86-89 Integra rear hub) $100 OEM Honda hub never opened 42200-SF4-008 (84 Civic 1300, 1500 Sedan/hatchback, CRX 1300, CRX 1500 rear hub) $80 B18C1 OBD2 distributor $120 H22A4 VTEC solenoid $20 D16Y8 busted as crap VTEC solenoid $1 F22B2 intake manifold WYSIWYG $50 D16Y7 intake manifold WYSIWYG $30 90 CRX Si clock $4 90 CRX Si main relay (unknown if it works, deleted from race car build) $5 90 CRX Si atmospheric pressure sensor $5 90 CRX Si light and wiper stalks (deleted from race car build) $10 D16Y7 airbox, intake arm, resonator (not pictured) $10 F22B2 valve keepers $12 F22B2 valves -1 exhaust $15 F22B2 block. Includes block, girdle, oil pump, balance shafts, crank end plate, main bolts, oil pickup. $50 F22B2 rods/pistons $10 F22B2 crank $25 B18B rocker arms $15 B18B rocker arm mount nuts $16 B18B valves $16 B18B valve keepers $12 B18B valve springs $15 D15B7 lower timing cover $2, belt tensioner $3, oil pressure sensor $1, water pump $5, alternator bracket w/bolts $1, oil pick up $1 D15B7 crank pulley with key and bolt (not pictured) $20 D15B7 oil pan $15 D16A6 distributor, needs cap and rotor. $50 DOHC ZC halfshaft $50 D16Z6 oil pan $15 D16Z6 oil pickup $1, water pump $5, alternator bracket w/bolts $1 D15B6 rods/pistons $10 D15B6 oil pan $12 B18C5 valve springs, 98k on them. Worked fine when removed. $40 B18C5 cam gears $10 B18C5 valves minus 2 intake. 98k on them. $25 96 D16Y7 5spd ECU works fine, removed from my car after changing to OBD-I. $15 00 D16Y8 ECU (unsure if its 5spd or not as I don't know much about the OBD-II VTEC ECU's) $15 Kirkey Drag Racing Layback seat 41 series with cover. I think its a 16 or 17". Will measure it. Never used, only mounted. $200 Link to comment Share on other sites More sharing options...
..SSR.. Posted March 13, 2008 Author Share Posted March 13, 2008 87 CRX Si transmission. Mileage unknown. Came out of a track only car. Quaife LSD. Comes with aftermarket axles, brand unknown. $1,000 shipped in the continental US. Link to comment Share on other sites More sharing options...
