91Civic3DrHb Posted February 19, 2008 Share Posted February 19, 2008 The '91 Civic 3 door hatchback I bought recently has a 4-speed manual transmisison. Ocassionally I try to shift to a non-existent 5th gear, because all the vehicles I've ever driven were 5 speeds. I'm guessing a 4-speed transmisison is cheaper than a 5-speed one, which is maybe why they put it in the standard model. 1. Do 5-speed transmissions translate to better fuel economy (everything else being equal)? 2. Can you swap the original 4-speed transmission from a '91 Civic for a 5-speed transmission? Thanks. Jay Quote Link to comment Share on other sites More sharing options...
zcef9 Posted February 19, 2008 Share Posted February 19, 2008 The '91 Civic 3 door hatchback I bought recently has a 4-speed manual transmisison. Ocassionally I try to shift to a non-existent 5th gear, because all the vehicles I've ever driven were 5 speeds. I'm guessing a 4-speed transmisison is cheaper than a 5-speed one, which is maybe why they put it in the standard model. 1. Do 5-speed transmissions translate to better fuel economy (everything else being equal)? 2. Can you swap the original 4-speed transmission from a '91 Civic for a 5-speed transmission? Thanks. Jay hey i got a 91 civic 3 door also im not to sure about fuel consumpsoin but i do know that you can take any d sereis tranny and it bolts right up with each other as long as it cable and not hydrolic but yea you can convert it to 5 speed Quote Link to comment Share on other sites More sharing options...
joe_112786 Posted February 19, 2008 Share Posted February 19, 2008 ya u can make it a 5 sp Quote Link to comment Share on other sites More sharing options...
Hatch92 Posted February 20, 2008 Share Posted February 20, 2008 you can put either a cable or a hydro 5-speed d-series tranny to your car. however if you want to use a hyrdo system you need to upgrade your current clutch system to hydro also. Quote Link to comment Share on other sites More sharing options...
James Matteu Posted February 20, 2008 Share Posted February 20, 2008 Do 5-speed transmissions translate to better fuel economy (everything else being equal)? No, the quantity of gears does not translate to fuel economy. The size of the gears is what has the greatest influence on fuel economy. A transmission with longer gears is designed for fuel economy, whereas a transmission with shorter gears is designed for rapid acceleration. Granted, most 5-speed Honda transmissions have shorter gears, there are a few 5-speed Honda transmissions with longer gears (usually coupled to PGM-Fi + VTEC-E Honda engines). Quote Link to comment Share on other sites More sharing options...
Blown330 Posted February 20, 2008 Share Posted February 20, 2008 As stated it depends on the gear ratios. All in all a 5-speed with closer ratio forward gears plus a taller overdrive will have better overall fuel economy than the 4-speed as long as the transmission doesn't add a gross amount of extra weight. Quote Link to comment Share on other sites More sharing options...
91Civic3DrHb Posted February 20, 2008 Author Share Posted February 20, 2008 Thanks for the replies. I'll leave things for now. If I ever need to replace the transmission, I might put in a 5-speed. Quote Link to comment Share on other sites More sharing options...
