grunt Posted February 1, 2008 Share Posted February 1, 2008 im going through my 99 si and i cant figure it out what will happen if the knock sensor is bad ? i have hardly any power at low rpms and im going through fuel like crazy Quote Link to comment Share on other sites More sharing options...
lceah Posted February 1, 2008 Share Posted February 1, 2008 You should post this in the "civic" section... and if your knock sensor is bad, what is happening to you is what would be expected to happen! your timing and air/fuel ratio are not optimum so your car is not fuel efficient... are you going to replace the sensor? Quote Link to comment Share on other sites More sharing options...
grunt Posted February 1, 2008 Author Share Posted February 1, 2008 no im not i ordered my ecu and it just has it removed Quote Link to comment Share on other sites More sharing options...
cranny Posted February 2, 2008 Share Posted February 2, 2008 your engine will run fine without t. honda ecu's dont use the knock sensor to make real time ignition changes so ive learned recently when reading about tuning. sounds like you might have a bad O2 snsor. what ecu are you talking about a chipped ecu? Quote Link to comment Share on other sites More sharing options...
lceah Posted February 2, 2008 Share Posted February 2, 2008 so then it's not the sensor...I learned something new...thanks cranny Quote Link to comment Share on other sites More sharing options...
Hatch92 Posted February 2, 2008 Share Posted February 2, 2008 it sounds like and O2 sensor and/or a plugged cat Quote Link to comment Share on other sites More sharing options...
