micgla Posted May 23, 2003 Share Posted May 23, 2003 Hi all, I have a problem with my 92 Honda Accord EX. I am hearing a noise (like a whining or bearing noise) coming from under the hood. Let me explain, I was driving home on the highway and started hearing a squeling noise. At the same time the battery light came on. Then about 20 seconds later the battery light went out. I checked under the hood when I got home and I found belt residue on the driveway. It looks like the ac/power stearing belt is rubbing(ever so slightly on the pulley that comes out of the engine(I believe this is the harmonic balancer). I just got this vehicle out of the shop and spent some bucks on a transmission computer and new brakes. Has anyone run into this type of scenario before? I heard that it could be altenator noise and I will need to replace it. Thanks for your help. Link to comment Share on other sites More sharing options...
..SSR.. Posted May 24, 2003 Share Posted May 24, 2003 Squealing usually = power steering. If there is a stain on your driveway from it, then it is power steering. Happened in my moms car. Link to comment Share on other sites More sharing options...
ImportGirl82 Posted May 26, 2003 Share Posted May 26, 2003 hopefully thats what it is..or you might be swapping motors...good luck Link to comment Share on other sites More sharing options...
micgla Posted May 26, 2003 Author Share Posted May 26, 2003 Well I figured out what is makiing the noise. The pulley that come out of the bottom of the engine that 2 belts run on has seperated. Is this going to be expensive to fix? Can I do this myself? Thanks for all the previous responces to this post. The engine still runs and sound fine it's just that the double pulley ( I believe this is the crankshaft pulley) has seperated. Any ideas? Link to comment Share on other sites More sharing options...
joecollins2 Posted July 1, 2003 Share Posted July 1, 2003 Good excuse to order aftermarket pulleys! Link to comment Share on other sites More sharing options...
