pico1671 Posted December 14, 2007 Share Posted December 14, 2007 should i put itr cams on my ctr head will it make a difference Link to comment Share on other sites More sharing options...
Hatch92 Posted December 15, 2007 Share Posted December 15, 2007 i thought the ITR and CTR have the same cams Link to comment Share on other sites More sharing options...
IVhorsemenmotorsports Posted December 16, 2007 Share Posted December 16, 2007 i thought the ITR and CTR have the same cams the CTR cams are more aggressive. they have more lift and duration than the ITR cams. Stick with the CTR cams unless you have the cash for aftermarket ones Link to comment Share on other sites More sharing options...
Nancy Posted December 18, 2007 Share Posted December 18, 2007 the CTR cams are more aggressive. they have more lift and duration than the ITR cams. Stick with the CTR cams unless you have the cash for aftermarket ones usdm 2000-2001 itr cams are the same spec as ctr cams. Link to comment Share on other sites More sharing options...
Hatch92 Posted December 18, 2007 Share Posted December 18, 2007 ^ thought so Link to comment Share on other sites More sharing options...
IVhorsemenmotorsports Posted December 18, 2007 Share Posted December 18, 2007 usdm 2000-2001 itr cams are the same spec as ctr cams. never mic'd or degree'd that year yet. what specs did you get out of them? Link to comment Share on other sites More sharing options...
cranny Posted December 18, 2007 Share Posted December 18, 2007 they are all 10.5mm lift i thought , maybe different dur's. Link to comment Share on other sites More sharing options...
IVhorsemenmotorsports Posted December 18, 2007 Share Posted December 18, 2007 they are all 10.5mm lift i thought , maybe different dur's. the spec i have for the ctr's are like in the 11mm range and longer duration Link to comment Share on other sites More sharing options...
