Otakubassist Posted August 26, 2007 Share Posted August 26, 2007 Okay, from what ive heard, the H23A1 head dosent breathe all that well. So I was wondering, would a 3 angle valve job and opening up the low end be sufficient, or would a 5 angle be the best bang for your buck? However, it is also a daily driver and needs to pass MD emissions and be reliable. Also, if I got the valve job, what type of cams would you suggest? Link to comment Share on other sites More sharing options...
..SSR.. Posted August 26, 2007 Share Posted August 26, 2007 5 angle doesn't do jack. All H/F heads flow really well from the factory. Throwing cams in it, you will more than likely fail emissions. Link to comment Share on other sites More sharing options...
michael vtec Posted September 18, 2007 Share Posted September 18, 2007 5 angle doesn't do jack. All H/F heads flow really well from the factory. Throwing cams in it, you will more than likely fail emissions. agreed. Link to comment Share on other sites More sharing options...
