spike10197 Posted August 10, 2007 Share Posted August 10, 2007 how would u wire an amp to a sony xplod CDX-CA650X model. ive been staring at it for ever and i have no clue on what to do. i know im a big newb but thats one thing im not really good at is wiring stuff. think anyone can help me out here? i got the amp and subs all for free so i want to put them in my car Link to comment Share on other sites More sharing options...
brynfiv Posted August 11, 2007 Share Posted August 11, 2007 how would u wire an amp to a sony xplod CDX-CA650X model. ive been staring at it for ever and i have no clue on what to do. i know im a big newb but thats one thing im not really good at is wiring stuff. think anyone can help me out here? i got the amp and subs all for free so i want to put them in my car Need a set of RCA wires to run from stereo to amp. A single strand of wire to run from blue (remote/power antenna) wire on back of stereo to remote terminal on amp. Have to run amp power wire all the way from battery +post to amp, and run amp ground (-) wire to something metal on car (bolt in bottom of hatchback, etc.) Use big enough wire for amp + and -. Also use inline fuse or wire could catch fire if amp ever shorts out. Seen it happen. Link to comment Share on other sites More sharing options...
spike10197 Posted August 11, 2007 Author Share Posted August 11, 2007 would a 60a fuse work? cuz that is what i got Link to comment Share on other sites More sharing options...
brynfiv Posted August 11, 2007 Share Posted August 11, 2007 would a 60a fuse work? cuz that is what i got ya, what size amp? Link to comment Share on other sites More sharing options...
spike10197 Posted August 11, 2007 Author Share Posted August 11, 2007 uhhh idk i think its 500 or 700 not to sure idk how u can tell Link to comment Share on other sites More sharing options...
brynfiv Posted August 11, 2007 Share Posted August 11, 2007 uhhh idk i think its 500 or 700 not to sure idk how u can tell Should say on it, but some don't. I'm running 4 gauge wire with 1000watt amp, it's a lil overkill. Your gonna need at least 8 gauge for 500-700 though. 60 amp fuse will work fine. Link to comment Share on other sites More sharing options...
spike10197 Posted August 11, 2007 Author Share Posted August 11, 2007 yeah i have the 8gauge. my friend gave me that with it. im still looking at all the stuff i need n what not im still confised lol Link to comment Share on other sites More sharing options...
cranny Posted August 11, 2007 Share Posted August 11, 2007 id go with at least 4 gauge , but thats me. Link to comment Share on other sites More sharing options...
spike10197 Posted August 11, 2007 Author Share Posted August 11, 2007 hmmm so now im lost do i go with 4 or 8? Link to comment Share on other sites More sharing options...
Shaft Posted August 12, 2007 Share Posted August 12, 2007 I would go with 4 gauge wire for sure. Sony amps are nutorious for using a ton of amperage to make power. If you don't give them enough current they over heat and go into a protect mode. 60 amp fuse would usually be a little over kill, but in the case of Sony.....probably just right. You will have to really watch where you put the amp. Put it in a place where it can get a lot of air to it, like I said before they are nutorious for over heating. Link to comment Share on other sites More sharing options...
Shaft Posted August 12, 2007 Share Posted August 12, 2007 Also forgot to tell you to make sure that you put the inline fuse no mre than 18" away from the battery. There is a reason why but I am not going to get into it. Link to comment Share on other sites More sharing options...
spike10197 Posted August 13, 2007 Author Share Posted August 13, 2007 hmmmm would it still be cool if i dont? Link to comment Share on other sites More sharing options...
Shaft Posted August 13, 2007 Share Posted August 13, 2007 I'm sure you would be fine with 8 gauge wire if you already have it run, just keep an eye on your amp if it starts to cut out at high volume I would change the wiring first. Let me know how you make out. Link to comment Share on other sites More sharing options...
CBRF4i Posted August 14, 2007 Share Posted August 14, 2007 hmmmm would it still be cool if i dont? no, put the fuse in. Its a fire hazard without it. Link to comment Share on other sites More sharing options...
Shaft Posted August 14, 2007 Share Posted August 14, 2007 Whoa! sorry I thought you wetre talking about the 8 gauge or 4 gauge wire thing. You definetly have to have the fuse in there. It protects the amp and the car from catching fire if your battery decides to dump a ton of amperage down the lines. Always, always a fuse from anything that is battery powered. Link to comment Share on other sites More sharing options...
spike10197 Posted August 14, 2007 Author Share Posted August 14, 2007 lol i ment would it be cool if i dont put the fuse at least 18" away from the battery? Link to comment Share on other sites More sharing options...
CBRF4i Posted August 14, 2007 Share Posted August 14, 2007 lol i ment would it be cool if i dont put the fuse at least 18" away from the battery? no, not cool fuse at least 18" away from battery. . again, its a fire hazard Link to comment Share on other sites More sharing options...
Xeryon Posted August 14, 2007 Share Posted August 14, 2007 if you put it further away you run the risk of shorting your system in the space between the fuse and the battery, and you do not want that. Link to comment Share on other sites More sharing options...
coolcat467 Posted August 14, 2007 Share Posted August 14, 2007 my fuse is mounted along the firewall Link to comment Share on other sites More sharing options...
spike10197 Posted August 14, 2007 Author Share Posted August 14, 2007 so can i just put it on the firewall? will it be fine there? Link to comment Share on other sites More sharing options...
coolcat467 Posted August 14, 2007 Share Posted August 14, 2007 thats where a lot of people put it. Link to comment Share on other sites More sharing options...
Shaft Posted August 16, 2007 Share Posted August 16, 2007 As long as it is no more than 18"from the battery Link to comment Share on other sites More sharing options...
spike10197 Posted August 16, 2007 Author Share Posted August 16, 2007 ahhh everyone is telling me 18" or firewall. someone just tell me one not 2 >_< Link to comment Share on other sites More sharing options...
coolcat467 Posted August 16, 2007 Share Posted August 16, 2007 or how about you be smart! ever think of putting it on the firewall 18 inches away from the battery? Link to comment Share on other sites More sharing options...
Xeryon Posted August 16, 2007 Share Posted August 16, 2007 Link to comment Share on other sites More sharing options...
