jonathanrodriguez100 Posted June 19, 2007 Share Posted June 19, 2007 Hi, I have an 2002 honda civic ex, I'm trying to find the ECU?? ALso I would like to run the ecu on test to see what codes it throws out?? can anyone help? Link to comment Share on other sites More sharing options...
Ben. Posted June 19, 2007 Share Posted June 19, 2007 ECU is located on the passenger side floorboard just beneath the dashboard to the right, before the door. Link to comment Share on other sites More sharing options...
jonathanrodriguez100 Posted June 19, 2007 Author Share Posted June 19, 2007 ECU is located on the passenger side floorboard just beneath the dashboard to the right, before the door. thanks busted, how can i put it on test to see what code is causing the check engine light? Link to comment Share on other sites More sharing options...
Ben. Posted June 19, 2007 Share Posted June 19, 2007 This eludes me. Lol. I really don't know, to be quite honest with you. Keep asking around, someone definitely knows. Link to comment Share on other sites More sharing options...
CRG7 Posted June 19, 2007 Share Posted June 19, 2007 If it's throwing codes, then you'll be able to count the number of flashes. No machinery required. Link to comment Share on other sites More sharing options...
cranny Posted June 19, 2007 Share Posted June 19, 2007 the ecu is not located whwre he told you. its in the dash behind the glove box. and as far as self diagnosing codes , i dont think you can with these models. Link to comment Share on other sites More sharing options...
jonathanrodriguez100 Posted June 19, 2007 Author Share Posted June 19, 2007 the ecu is not located whwre he told you. its in the dash behind the glove box. and as far as self diagnosing codes , i dont think you can with these models. Thanks Cranny your right, I might need to go to the dealer? Or is there a tool that has the MIL light flashing and that gives you the code? Link to comment Share on other sites More sharing options...
neto66 Posted June 19, 2007 Share Posted June 19, 2007 does anyone know where the ecu on a 99 civic ex is? Link to comment Share on other sites More sharing options...
cranny Posted June 19, 2007 Share Posted June 19, 2007 the first location mentioned. behind passenger side kick panel. jonathon , ive done some reading on this since i have the same car. behind your center console(climate controls) , if you take it out , theres a blue 2 pin connector like all other models. ive never tried , but try crossing it and see if the car flashes codes. ive read that it does but have never tried yet. Link to comment Share on other sites More sharing options...
Ben. Posted June 19, 2007 Share Posted June 19, 2007 the ecu is not located whwre he told you. its in the dash behind the glove box. and as far as self diagnosing codes , i dont think you can with these models. Oof. I'm outta the loop past '00 model Civic's. Lol. Link to comment Share on other sites More sharing options...
dbtower Posted June 19, 2007 Share Posted June 19, 2007 no no no no no........you cannot jumper the connector and get the codes...it is obdIIb take it to a auto store and they should be able to tell you what it is for free Link to comment Share on other sites More sharing options...
