hatchciv92 Posted June 14, 2007 Share Posted June 14, 2007 i need the most info you caN Give me on b20 vtec. what can i do to make that bottom end a little stronger.. i want to get a b20 and drop my b16a2 head on there. but i want that bottom end to hold. thank you. Link to comment Share on other sites More sharing options...
Ben. Posted June 14, 2007 Share Posted June 14, 2007 You'll probably want to rebuild the bottom end with better parts if you're wanting it to hold up to that 8,000 rpm redline. Link to comment Share on other sites More sharing options...
hatchciv92 Posted June 14, 2007 Author Share Posted June 14, 2007 You'll probably want to rebuild the bottom end with better parts if you're wanting it to hold up to that 8,000 rpm redline. yeah i want to know what i have to do to rebuild it.. i need what parts..???? Link to comment Share on other sites More sharing options...
Ben. Posted June 14, 2007 Share Posted June 14, 2007 Umm.. CP Pistons, Pauter Rods and Pauter Crank if you have the money.. Wouldn't hurt. Good crap. Link to comment Share on other sites More sharing options...
hatchciv92 Posted June 14, 2007 Author Share Posted June 14, 2007 Umm.. CP Pistons, Pauter Rods and Pauter Crank if you have the money.. Wouldn't hurt. Good crap. no pistons??? and where could i find those stuff easier Link to comment Share on other sites More sharing options...
Ben. Posted June 14, 2007 Share Posted June 14, 2007 .. There's a member of this site that sells CP Pistons and I think he deals with either Eagle or Pauter for Rods and maybe crankshafts. ..SSR.. is his user name Link to comment Share on other sites More sharing options...
hatchciv92 Posted June 14, 2007 Author Share Posted June 14, 2007 .. There's a member of this site that sells CP Pistons and I think he deals with either Eagle or Pauter for Rods and maybe crankshafts. ..SSR.. is his user name alright, thank you,.. so what'\s the cheaper way of making it hold???lol Link to comment Share on other sites More sharing options...
hatchciv92 Posted June 14, 2007 Author Share Posted June 14, 2007 one more question.. why dont they hold past 7000rpms?? Link to comment Share on other sites More sharing options...
Ben. Posted June 14, 2007 Share Posted June 14, 2007 They weren't built for it. B20 internals are low compression and designed for at best 7K. Link to comment Share on other sites More sharing options...
hatchciv92 Posted June 14, 2007 Author Share Posted June 14, 2007 They weren't built for it. B20 internals are low compression and designed for at best 7K. so what'\s the cheaper way of making it hold?? Link to comment Share on other sites More sharing options...
Kegger Posted June 15, 2007 Share Posted June 15, 2007 Buy a B18C type-r block. There is no cheap way to make a B20 bottom end hold that. Link to comment Share on other sites More sharing options...
cranny Posted June 15, 2007 Share Posted June 15, 2007 just rebuild the B20 bottom end , get whatever pistons you plan on running , have them sized to the engine , buy oversized pistons. get the stock rods shotpeened and honed , crank balanced and polished. the bottom end clearanced for bearings. get a set of ARP rod bolts. than your engine will be good for 7000 rpm all day long , which is all you need , cause with a B16 head , you wont make any power past that anways. if you want insurance , get aftermarket rods. than if you decide on cams and head upgrade down the road , you will be able to rev to 8000 or past. Link to comment Share on other sites More sharing options...
hatchciv92 Posted June 15, 2007 Author Share Posted June 15, 2007 just rebuild the B20 bottom end , get whatever pistons you plan on running , have them sized to the engine , buy oversized pistons. get the stock rods shotpeened and honed , crank balanced and polished. the bottom end clearanced for bearings. get a set of ARP rod bolts. than your engine will be good for 7000 rpm all day long , which is all you need , cause with a B16 head , you wont make any power past that anways. if you want insurance , get aftermarket rods. than if you decide on cams and head upgrade down the road , you will be able to rev to 8000 or past. ok one more question... how bout if i put that b16 head on there without building it and i woudn't try to past 7k what would happen to it/././.??> Link to comment Share on other sites More sharing options...
Kegger Posted June 15, 2007 Share Posted June 15, 2007 Have you ever seen a rod go thru a firewall? If you don't want to, don't try it. Link to comment Share on other sites More sharing options...
cranny Posted June 15, 2007 Share Posted June 15, 2007 you cant dude , it needs rebuilding , its just the way it is. Link to comment Share on other sites More sharing options...
yoyovroom Posted June 18, 2007 Share Posted June 18, 2007 you cant dude , it needs rebuilding , its just the way it is. i had a stock b20 bottom end and got everything tuned i was pulling 8200 but then again it blew the same night so yea listen to these guys build it thats what i did i ran 11.9's all day with a allmotor b20/vtec setup get a forged crank and forged rods with forged studs and you should be fine if you really want to last get cast iron sleeves those crapty aluminum sleeves dont hold crap Link to comment Share on other sites More sharing options...
..SSR.. Posted June 18, 2007 Share Posted June 18, 2007 You don't need a crank. The rods suck because they use the same rod bolts as a D16. Link to comment Share on other sites More sharing options...
yoyovroom Posted June 19, 2007 Share Posted June 19, 2007 You don't need a crank. The rods suck because they use the same rod bolts as a D16. you need a crank to make powa i dont know how you buid but here in houston we build to be fast a stock crank will snap at around 350-400 hp Link to comment Share on other sites More sharing options...
cranny Posted June 19, 2007 Share Posted June 19, 2007 not in a honda bud. honda cranks can handle all the power you can afford to put to it. it is a forged crank stock. Link to comment Share on other sites More sharing options...
Ben. Posted June 19, 2007 Share Posted June 19, 2007 you need a crank to make powa i dont know how you buid but here in houston we build to be fast a stock crank will snap at around 350-400 hp Yes, tard. But you fail to understand that horsepower isn't what snaps crap. It's torque. Aaaand being as Honda's are generally the torqueless wonder of the car world...hmmm... Link to comment Share on other sites More sharing options...
