weefrenchsailor Posted June 14, 2007 Share Posted June 14, 2007 my 97 sol is going to be used mostly for autox/honda challenge thanks mostly to my recent purchase of a 93 hatch (crap winter in ohio sucks). so my question is which would be better, the koni/ground control set up (which i hear is hard to beat) or some tein coilovers? the springs for the tein are 10kg/mm front and 7kg/mm rear. stiff crap!! but good for auto cross? i also have polyeurathane bushings and sway bars. planning on tie bars and tower bars. anybody with experience with either set up please help!! Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted June 14, 2007 Share Posted June 14, 2007 Koni/GC. Link to comment Share on other sites More sharing options...
weefrenchsailor Posted June 14, 2007 Author Share Posted June 14, 2007 going with the koni/cg, what spring rate would you reccomend? i heard 450f and 500r is a good set up. i was planning on lowering the car about 1.5"f and 2" in the rear. would i bottom out? Link to comment Share on other sites More sharing options...
TS John Posted June 14, 2007 Share Posted June 14, 2007 You can lower a lot more than that on a del sol without bottoming. I was 1.5" lowered with no problems except on some troublesome speed bumps. Link to comment Share on other sites More sharing options...
