optional187 Posted April 7, 2003 Share Posted April 7, 2003 hmmm...well. my check engine light came on. hasn't gone off. just wondering what the deal is? it did it a day or two after i put on my aem intake...it drives normal and a few people that i know said that it happened to them too when they put on their intakes. is the o2 sensor just getting confused because i'm flowing more air in and a little more air out? Link to comment Share on other sites More sharing options...
VerkineX Posted April 7, 2003 Share Posted April 7, 2003 If you would have reset the chip in your car when you put the intake in your engine would automatically be used to the intake whereas now it might take a while for it to agree, and you wont get as much hp as you might have, most people put alot of aftermarket parts at once then put a aftermarket chip on to reset the engine so it will be used to everything and you can get the max hp possible. Link to comment Share on other sites More sharing options...
the1darkprince Posted April 7, 2003 Share Posted April 7, 2003 so, could he put all the original stuff back in...redo everything with resetting the chip? how would you reset the chip? -Kirkus Link to comment Share on other sites More sharing options...
JDM Jackass2 Posted April 7, 2003 Share Posted April 7, 2003 if you install an air intake correctly you arn't supposed to get any CEL lights. hell, when i install a whole different engine i don't get CELs. whatever, crap happens. reset your ECU by disconnecting the negative cable from the battery for 20 minutes. Link to comment Share on other sites More sharing options...
optional187 Posted April 7, 2003 Author Share Posted April 7, 2003 i'll go try that out right now. THANX! Link to comment Share on other sites More sharing options...
civic_ricer Posted April 8, 2003 Share Posted April 8, 2003 Well, I couldn't tell you what is happening. My light never came on since I put my intake on... Link to comment Share on other sites More sharing options...
