92civic21 Posted April 8, 2007 Share Posted April 8, 2007 i have a 94 dx hatch. i just got a jdm b16a. the harness on the motor was cut on both sides. im going to do the swap this weekend and i just want some heads up on how to do the vtec wiring. i know i can do everything else but i dont know about the wiring. btw can i use my d shift linkage or no? if i cant will b obd0 linkage work? Link to comment Share on other sites More sharing options...
cranny Posted April 8, 2007 Share Posted April 8, 2007 you need to talk to EH6. Link to comment Share on other sites More sharing options...
92civic21 Posted April 8, 2007 Author Share Posted April 8, 2007 and who might he be? Link to comment Share on other sites More sharing options...
airjordan223 Posted April 8, 2007 Share Posted April 8, 2007 EH6TunerDaniel Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted April 8, 2007 Share Posted April 8, 2007 Lawls. Why does he need to talk to me?......I didnt have to wire vtec. It was already wired.... You need to add in a knock sensor, vtec pressure switch and vtec solenoid. Wire them to these pins on the ecu. Knock sensor goes to pin D-3 vtec pressure switch goes to pin D-6 vtec solenoid goes to pin A-4 You will also need B Series shift linkage. Stay away from Del Sol VTEC shift linkage. Link to comment Share on other sites More sharing options...
cranny Posted April 9, 2007 Share Posted April 9, 2007 giving you a chance to share your new wisdom dude , lol. Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted April 9, 2007 Share Posted April 9, 2007 Lol, thanks. Haha. Link to comment Share on other sites More sharing options...
92civic21 Posted April 9, 2007 Author Share Posted April 9, 2007 does it matter if the linkage is obd0. my friend had a ls(a1) in his crx. would that linkage work? hes working on putting a h22 in it now. Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted April 9, 2007 Share Posted April 9, 2007 I dont know. I would just get one from a 94-01 integra or 92-00 b series civic. Link to comment Share on other sites More sharing options...
92civic21 Posted April 9, 2007 Author Share Posted April 9, 2007 alright well thanks for the help. u put me like 10 steps ahead Link to comment Share on other sites More sharing options...
92civic21 Posted April 9, 2007 Author Share Posted April 9, 2007 the knock sensor is the green plug right above the oil filter, right? Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted April 9, 2007 Share Posted April 9, 2007 Yeah....Single wire circular plug. I think the actual plug is green. Then sensor itself should be black. Link to comment Share on other sites More sharing options...
cranny Posted April 9, 2007 Share Posted April 9, 2007 its as close to the head as you can get. closer to drivers side. one wire plug. Link to comment Share on other sites More sharing options...
92civic21 Posted April 11, 2007 Author Share Posted April 11, 2007 theres a plug on the front of the tranny. 2 wire plug. both green wires. whats it for? Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted April 11, 2007 Share Posted April 11, 2007 Reverse light switch maybe??? Pics. Link to comment Share on other sites More sharing options...
92civic21 Posted April 17, 2007 Author Share Posted April 17, 2007 ok i got her all in and everything but she wont start. everytime i turn the key all u hear is the fuel pump. i dont think im getting any spark. she wont even try to turn over. my buddy was messing around in the car trying to start it and i was screwing a spark plug back in and as i was doing that he tried starting it and she tried to turn over a few times. i was like wft. after that i could it to do anything. what should i look for or try to do? Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted April 17, 2007 Share Posted April 17, 2007 If it wont turn over, you need to check if it is your starter first. Try turning the key on, have someone press the clutch for you, and jump the solenoid on the starter. If you get nothing, you will need a new starter. If it turns over but doesnt do it with the key, then its more than likely the ignition switch. After you get it to turn over upon request, then try to start it and try troubleshooting if it still doesnt start. Link to comment Share on other sites More sharing options...
Kegger Posted April 17, 2007 Share Posted April 17, 2007 You need a ground from the head or block to the frame. The one you have sucks. Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted April 17, 2007 Share Posted April 17, 2007 Where do you see this ground? I saw no pictures..... Too bad your swap couldnt have been like mine. Started up first try no warm ups. Link to comment Share on other sites More sharing options...
92civic21 Posted April 17, 2007 Author Share Posted April 17, 2007 well how do i know if my ground dont suck. i have 2. one from the block and one from the head. how it was stock. Link to comment Share on other sites More sharing options...
92civic21 Posted April 17, 2007 Author Share Posted April 17, 2007 yea i wish mine did that. its just sitting out there waiting to be driven. Link to comment Share on other sites More sharing options...
Kegger Posted April 17, 2007 Share Posted April 17, 2007 Yeah but I'm betting when you were putting in that plugs you grounded out the VC, so it let the juice flow and it turned over. Link to comment Share on other sites More sharing options...
92civic21 Posted April 17, 2007 Author Share Posted April 17, 2007 vtec is wired now. what do you think? Link to comment Share on other sites More sharing options...
Kegger Posted April 17, 2007 Share Posted April 17, 2007 The problem is that the VC isn't actually touching the head. Rubber in this case is not your friend. find a spot on the side of the block where the timing belt cover bolts on, pull one of the bolts, put your ground cable over the hole between the block and the cover then bolt it back on. Should turn right over. Link to comment Share on other sites More sharing options...
