dropshadowinc Posted January 24, 2007 Share Posted January 24, 2007 hey guys i just bought a 94 hatch and its already got p&p head and intake mani, skunk 2 stage 2 cams, and a valve job. i plan on havin a 3 angle valve job done along with a bigger tb and a new intake mani. however i want to turbo it so i need to kno what crank/ pistons/ rods you guys feel are the best. i want to run something in the lines of 15-20 psi. oh yea its a b16 engine btw Link to comment Share on other sites More sharing options...
boostedb16 Posted January 26, 2007 Share Posted January 26, 2007 You can run the stock crank if you want. Just go have it turned, balanced and fitted to your rods and bearings. Go w/ Eagle H-beam rods and JE pistons. You'll like the combination. Link to comment Share on other sites More sharing options...
..SSR.. Posted January 27, 2007 Share Posted January 27, 2007 Sotck heads have 3 angle. Most porters use 3 angle, so you don't need a new valve job. You'd need to replace your seats anyways for another. Ditch the cams if you're going turbo. Stock crank, DO NOT have it turned. RM rods w/ CP Pistons. Link to comment Share on other sites More sharing options...
