Joe W Posted January 12, 2007 Share Posted January 12, 2007 Okay so I'm trying to learn a bit more about the options for a d15b(JDM). First off what d series pistons will work and what ones wont work? which would be best for n/a? Next what is the combustion chamber volume (cc)? Thats all I have for now, anyone's opinion is welcome but would like reliable information. Thanks Forgot to mention it will be a dd for the most part, just something to have fun with and have some track possibilities. Link to comment Share on other sites More sharing options...
Ben. Posted January 13, 2007 Share Posted January 13, 2007 Okay so I'm trying to learn a bit more about the options for a d15b(JDM). First off what d series pistons will work and what ones wont work? which would be best for n/a? Next what is the combustion chamber volume (cc)? Thats all I have for now, anyone's opinion is welcome but would like reliable information. Thanks Forgot to mention it will be a dd for the most part, just something to have fun with and have some track possibilities. ... d series pistons will work with d-series motors..obviously. Link to comment Share on other sites More sharing options...
Joe W Posted January 13, 2007 Author Share Posted January 13, 2007 yeah d series pistons may fit but might not be right for the motor if they give too high of a compression. Link to comment Share on other sites More sharing options...
Ben. Posted January 13, 2007 Share Posted January 13, 2007 No oem d-series pistons have too high a compression ratio to go into another d series motor dude. What wouldn't be right for the motor is if say, some dumbass went and put some 10.5:1 comp pistons in his motor and then tried to boost 14 or 15 pounds on it. Is that what you were planning on? Link to comment Share on other sites More sharing options...
..SSR.. Posted January 13, 2007 Share Posted January 13, 2007 Wrong. P29's in a Y8 put you in the 13:1'ish range. Only two D series pistons will fit. It has the best of the two already. Link to comment Share on other sites More sharing options...
Ben. Posted January 13, 2007 Share Posted January 13, 2007 Wrong. P29's in a Y8 put you in the 13:1'ish range. Only two D series pistons will fit. It has the best of the two already. That's a little high. Oh well. Link to comment Share on other sites More sharing options...
Joe W Posted January 13, 2007 Author Share Posted January 13, 2007 It has the P08 pistons right? and those are the best for the d15b, so what kind of work would you recommend doing to the block/head? Link to comment Share on other sites More sharing options...
..SSR.. Posted January 14, 2007 Share Posted January 14, 2007 Nothing to the block if a compression and leakdown test come out good. If not, then re-ring it and ARP rods bolts and HS. Headwork valve train cam Link to comment Share on other sites More sharing options...
Joe W Posted January 14, 2007 Author Share Posted January 14, 2007 Thanks for the input ..SSR.. What brand(s) would you recommend for headwork headwork? Link to comment Share on other sites More sharing options...
Ben. Posted January 14, 2007 Share Posted January 14, 2007 RM Cam/Valvetrain FTW. Link to comment Share on other sites More sharing options...
..SSR.. Posted January 15, 2007 Share Posted January 15, 2007 Correct. Link to comment Share on other sites More sharing options...
Joe W Posted January 15, 2007 Author Share Posted January 15, 2007 Earlier I went the website and found the cam and valvetrain for $990.00, but im not positive how i would go about ordering it. Would I have to call and place an order or some other way? Link to comment Share on other sites More sharing options...
..SSR.. Posted January 16, 2007 Share Posted January 16, 2007 Thats for B series. D cams are custom made. Contact me via email to order. Link to comment Share on other sites More sharing options...
Joe W Posted January 16, 2007 Author Share Posted January 16, 2007 Ok will do, but i think itll be closer to summer when i order. Thanks for all the info. Link to comment Share on other sites More sharing options...
