antballer02 Posted January 4, 2007 Share Posted January 4, 2007 i just lower my car and my rear right side is toeing in alot and i adjusted the alignment bolt to the max. what should i get? Link to comment Share on other sites More sharing options...
cranny Posted January 4, 2007 Share Posted January 4, 2007 sounds like somin else might be wore out. Link to comment Share on other sites More sharing options...
les.delancy Posted January 5, 2007 Share Posted January 5, 2007 Alignment bolt? What kind of car are we talking about? Obviously a Honda, so it almost has to be rack and pinion steering. You shortened the tie rod? The first thing you need to check for is worn out (loose or "sloppy") tie rod ends. Jack up the problem wheel and see if you can turn it in and out (front and back) with your hands. If so, you almost certainly have a bad tie rod end. Look under the car while wiggling the wheel and look at the tie rod (the piece connecting your steering rack to the knuckle). It could either be the outer end (at the knuckle), or the inner end (at the rack inside of the boot). If you have the latteral movement and no bad tie rod ends it could be a loose hub bearing; check for the same tyoe of movement top to bottom. That should get you started, if that's not it, check the tie rods on the other side. If you still don't find anything, check for loose or worn rack bushigs. It could also be a control arm bushing and or ball joint (though less likely). Hope this helps. If you have any more question, just ask! Link to comment Share on other sites More sharing options...
cranny Posted January 5, 2007 Share Posted January 5, 2007 theres toe adjustment in the front and back , but thats it , no camber or castor. Link to comment Share on other sites More sharing options...
les.delancy Posted January 6, 2007 Share Posted January 6, 2007 theres toe adjustment in the front and back , but thats it , no camber or castor. No camber or caster in the front or rear? Really, OK! And you called me an idiot?! :nono: Link to comment Share on other sites More sharing options...
CleanGSR Posted January 6, 2007 Share Posted January 6, 2007 I don't know abot the caster, but there definately isn't any camber adjustments on the front or rear. Link to comment Share on other sites More sharing options...
