mocker75 Posted November 20, 2006 Share Posted November 20, 2006 I just dropped my new zc into my 91 crx. One of the problems I came across is the clutch cable. We hooked it up where it needed to be but when the clutch pedal is pressed to the floor it sticks there. If just tap the pedal back out it comes right back no problem. One thing I haven't tried is hooking up all the shift linkage yet (not too sure if that has anything to do with it or not). Anyone have an idea what this could be? Or possibly things to check? Thanks Link to comment Share on other sites More sharing options...
HONDA CRX 88 SI Posted November 20, 2006 Share Posted November 20, 2006 double check everything man make sure everything is right and adjusted. Link to comment Share on other sites More sharing options...
90IntegraC1 Posted November 20, 2006 Share Posted November 20, 2006 there's tiny cotter pins in the clutch assembly that help it spring back....check those... Link to comment Share on other sites More sharing options...
Hatch92 Posted November 20, 2006 Share Posted November 20, 2006 i would have to say the spring is either missing or needs to be replaced. Link to comment Share on other sites More sharing options...
90IntegraC1 Posted November 20, 2006 Share Posted November 20, 2006 doesn't the spring=cotter pins?? hmmm, that's what i was referring too... Link to comment Share on other sites More sharing options...
Hatch92 Posted November 20, 2006 Share Posted November 20, 2006 ok you win Link to comment Share on other sites More sharing options...
90Tegtyper Posted November 20, 2006 Share Posted November 20, 2006 ok you win cotter pins and springs are different Link to comment Share on other sites More sharing options...
cranny Posted November 20, 2006 Share Posted November 20, 2006 might be too tight. adjust it so you have 1/2 inch freeplay when peddle is all the way out , and so it grabs half way out approx. Link to comment Share on other sites More sharing options...
