nosaj81_2000 Posted February 19, 2003 Share Posted February 19, 2003 well come this time next year im thinking of getting a b16a for the 91 civic lx. should i start buying stuff for the motor throughout the year but im not sure what all to buy for a b16a or should i get a better motor. some help i think is in order for me because im not sure what to get. (i can start buying some stuff for the car but they are not nessecarly part of the engine mostly for the suspension.) Link to comment Share on other sites More sharing options...
EGRacer Posted February 19, 2003 Share Posted February 19, 2003 i would say get your suspension done first. maybe 2-3" drop all way around. then buy exhaust, cai, turbo setup, do the internals(when u get motor), bore it out(when u ahev motor), then get ignition box, wires, plugs, and 50 gallon drum of race fuel(hehehe) Link to comment Share on other sites More sharing options...
nosaj81_2000 Posted February 19, 2003 Author Share Posted February 19, 2003 so what kind of motor should i get the b16a or better Link to comment Share on other sites More sharing options...
EGRacer Posted February 19, 2003 Share Posted February 19, 2003 b16a1 or b16a2 would be fine. but a gsr or itr motor would suit you nicely Link to comment Share on other sites More sharing options...
nosaj81_2000 Posted February 19, 2003 Author Share Posted February 19, 2003 so which is better with the most aftermarket out for it Link to comment Share on other sites More sharing options...
S14Silvia Posted February 19, 2003 Share Posted February 19, 2003 b16a is cheaper then a gsr. you could go with a crower stroker kit which would allow you to specify a lower compression ratio such as 9.5:1 or 9:1, you'd also get h-beamed rods. or you could go with h-beamed rods, bore out the cylinders to 84 mm instead of the stock 81mm and retain the b16a's almost perfect rod to stroke ratio which is what allows it to rev like it does. combine those internals with a t3/t4 turbo or better for a street car an hks gt2840 and you'll hit some awesome hp numbers. Link to comment Share on other sites More sharing options...
EGRacer Posted February 20, 2003 Share Posted February 20, 2003 b16a is cheaper then a gsr. you could go with a crower stroker kit which would allow you to specify a lower compression ratio such as 9.5:1 or 9:1, you'd also get h-beamed rods. or you could go with h-beamed rods, bore out the cylinders to 84 mm instead of the stock 81mm and retain the b16a's almost perfect rod to stroke ratio which is what allows it to rev like it does. combine those internals with a t3/t4 turbo or better for a street car an hks gt2840 and you'll hit some awesome hp numbers. very very nicely said. i could not have said it better myself. but there are a couple things i will reccomend if u go with the turbo setup. make sure you have your motor sleeved, ported, polished, multi-angle valve job, and then get a couple of ignition upgrades. liek a msd sci ignition box, msd wires, msd blaster 2 coil, splitfire plugs Link to comment Share on other sites More sharing options...
nosaj81_2000 Posted February 20, 2003 Author Share Posted February 20, 2003 so where would i be able get this stuff so that i will already have it for when i get my new motor next year. please someone tel me. Link to comment Share on other sites More sharing options...
S14Silvia Posted February 20, 2003 Share Posted February 20, 2003 to get stuff for your car? um call to any shop to see if they are a dealer for hks would be a good start, if you cant find a dealer wholesalehyperformance should have most of the stuff. i'm not sure if there is actually a kit from hks out right now, but you can always call them up and they'd be more then happy to help you setup your kit to your specs. JE, Arias, Crower are all good places for pistons and rods, but i personally am a big fan of Endyne they make really awesome pistons that range anywhere from 7.5-14.1 c.r. so they would be the best option for your engine set up. Link to comment Share on other sites More sharing options...
nosaj81_2000 Posted February 22, 2003 Author Share Posted February 22, 2003 sweet dude they should have an 800 number on there site right. Link to comment Share on other sites More sharing options...
