How to install techometer
JdmRider
Posted
Can anyone help me and tell me how to install a techometer on a 2000 Honda Civic w/ 5 speed trany
or show me some pictures please. Thank You
Posted
really easy...there is a red/black/white/greeen wire..
red=power source (hook up to your red wiree on your deck)
black=ground(hook up to your black wire on your deck
white=dash light(hook up to orange wire on deck)
green=there should be a green wire on your distributor car wires. splice that and connect the remaining wire that comes with your tachometer to that....
Posted
you dont need pics for this. how many wires comming out of it 3? power ground and signal. power goes to accessory power id say. ground goes to ground , lol. and signal goes to your tach signal wire comming from dizzy. and youl be happy to know , its the solid blue wire.
Posted
is installation the same for a 94 ex coupe? >civic
yes...from my knowledege...89-2000 are the same as long as it doesn't have elctronic spark like how the k20 in the rsx does....
Posted
01-up civics as well , distributorless ignition.
Posted
Thank you everyone. Did everything correct but its still not picking
up the R.P.M. from my car. Does anyone know why. The brand of
the tech is Faze. My be I should just get my money back and get
a AutoMeter gauge what does everyone think. Hope you got answers.
Posted
If you really think you did everything right then return the tach and have the retailer replace it. The one you have could be bad. So if you have it replaced its free and easy to install because you know how to do it.
But make sure you know that everything is wired correctly first.
Posted
if you are gonna get the autmeter gauge...you are gonna have to cut some wires running out of the tach...it is gonna be 3 wires...not sure...
Posted
If you try and do it again and cant get it..
Consider getting a gauge out of an ex, its just plug and play and it works... Take the old one out, plug the new one in...
Thats what I did, really clean look and I dont have to risk getting it stolen..
