92ge Posted November 6, 2006 Share Posted November 6, 2006 i drive a 92 civic vx and my speedometer does not work...it only works sometimes if i really hit the damn thing...hahaa...should i just go and buy a used cluster?...or what could be wrong... Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted November 6, 2006 Share Posted November 6, 2006 Maybe its a loose wire behind the cluster. If it ends up being your VSS (which I doubt, because hitting your sluster wont make it work), I have one I would sell you. Link to comment Share on other sites More sharing options...
civicplaya20 Posted November 6, 2006 Share Posted November 6, 2006 Check to make sure all of the plugs in the back are tight, if they are I would get another one. The only problem with that is if the miles don't match. I got a whole new cluster and the miles were no where near where they needed to be so I had to roll them by hand. You can do all that if you want if the miles matter to you that is. Link to comment Share on other sites More sharing options...
92ge Posted November 6, 2006 Author Share Posted November 6, 2006 Maybe its a loose wire behind the cluster. If it ends up being your VSS (which I doubt, because hitting your sluster wont make it work), I have one I would sell you. wat is VSS? and how much did you want for it? Link to comment Share on other sites More sharing options...
RazorbackMustang Posted November 9, 2006 Share Posted November 9, 2006 wat is VSS? and how much did you want for it? My 96 does the exact same thing and I replaced the VSS to no avail. The VSS is the Vehicle Speed Sensor. Your speedo head unit is the most likely culprit. Link to comment Share on other sites More sharing options...
HONDA CRX 88 SI Posted November 9, 2006 Share Posted November 9, 2006 yeah i am going more for the cluster, the vss i really dont think that is in this case. Link to comment Share on other sites More sharing options...
cranny Posted November 9, 2006 Share Posted November 9, 2006 VSS in a 92? cable speedo in 92 wasnt it? maybe im wrong. 92 tegs have cable speedo. and i cant see a civic gettin an option acura cars dont have. Link to comment Share on other sites More sharing options...
92ge Posted November 10, 2006 Author Share Posted November 10, 2006 VSS in a 92? cable speedo in 92 wasnt it? maybe im wrong. 92 tegs have cable speedo. and i cant see a civic gettin an option acura cars dont have. my cluster right now doesn't have a cable...its all wires and connectors...anywais...my speed works on and off still. it will work fine when i drive it for a while. when i park it overnight and then drive it the next day....it wont work until i actually hit the thing...? still don't know what the problem is Link to comment Share on other sites More sharing options...
cranny Posted November 10, 2006 Share Posted November 10, 2006 your cluster has only wiring connectors plugged into it? if so get a VSS. Link to comment Share on other sites More sharing options...
FiRe_OpTiKz© Posted November 10, 2006 Share Posted November 10, 2006 check your wiring in the cluster pull your top dash out {plast part} and make sure the wires are in the cluster right Link to comment Share on other sites More sharing options...
