89crxsi1003 Posted November 6, 2006 Share Posted November 6, 2006 Ok ive got a 1989 SI and going to do a B16a2 swap motor and tranny with 61,000 for 2200.00 good price? well the question i have is what ECU will come with this motor its bone stock? and i know i will need axles,mounts,shift linkage. is that all ill need and where will i get the parts from what kind of honda what years or will this all have to be bought with like a swap kit?. i know im going with hasport mount.Is there a better then stock axle to go with?? Thanks:TIM Link to comment Share on other sites More sharing options...
sonnyjc3 Posted November 6, 2006 Share Posted November 6, 2006 Ok ive got a 1989 SI and going to do a B16a2 swap motor and tranny with 61,000 for 2200.00 good price? well the question i have is what ECU will come with this motor its bone stock? and i know i will need axles,mounts,shift linkage. is that all ill need and where will i get the parts from what kind of honda what years or will this all have to be bought with like a swap kit?. i know im going with hasport mount.Is there a better then stock axle to go with?? Thanks:TIM the ecu will prolly come with the motor. if it doesnt you can get one off ebay or craigslist, or snag one off a 96/97 del sol vtec, or an ek civic si. Link to comment Share on other sites More sharing options...
KvN Posted November 6, 2006 Share Posted November 6, 2006 or u can grab it off of a b16a2 is that the dohc vtec 1.6? if it is then grab it off the 2000 civic si same motor Link to comment Share on other sites More sharing options...
cranny Posted November 6, 2006 Share Posted November 6, 2006 preferably for you , a 1st gen OBD0 ECU would be best. unless your future plas include tuning , in which case go OBD1 now. OBD0 - PR3 , PW0 OBD1 - P30 , P28 if your chipping it. Link to comment Share on other sites More sharing options...
89crxsi1003 Posted December 2, 2006 Author Share Posted December 2, 2006 ok im about to order my motor now the question is its a hydralic tranny can u change my cable to a hydralic? in know if its possible ill need master,brake line,slave cylinder. or should i buy one of the conversion kit for 400.00? 1 more thing crx's dont have power steering and the b16a2 is so do i just not use the pump and remove it?? Thanks for all the advice Link to comment Share on other sites More sharing options...
Kastigir Posted December 2, 2006 Share Posted December 2, 2006 ok im about to order my motor now the question is its a hydralic tranny can u change my cable to a hydralic? in know if its possible ill need master,brake line,slave cylinder. or should i buy one of the conversion kit for 400.00? 1 more thing crx's dont have power steering and the b16a2 is so do i just not use the pump and remove it??Thanks for all the advice You can, but it's going to be easier to find a cable tranny instead. Also, if you're keeping the CRX rack, which I see no reason not to, then remove the power steering pump. In fact, it might not fit anyway. Link to comment Share on other sites More sharing options...
..SSR.. Posted December 3, 2006 Share Posted December 3, 2006 Get a cable trans. You'll need a conversion harness for the ECU. Get a P28 and a harness from kingmotorsports.com (look under Boomslang). Autozone axles. Lifetime warranty owns. Link to comment Share on other sites More sharing options...
cranny Posted December 4, 2006 Share Posted December 4, 2006 +1 for cable trans , you dont even want to get into that. dont worry about power steering. its of no concern as your car isnt power steering. this way you dont need to run extra accessorys of the engine anyways. he wont need a conversion harness if he runs it OBD0. IACV wire conversion. and eliminate the CKF(crank fluctuation sensor located on crank pully side of engine behind timing cover). the 99-00 B16A2 dizzy will work fine too. you can use that dizzy for OBD0. just needs to be repinned. or best way to do it , would be to hack your engine harness thats in the car , get the preplug for the dizzy off an OBD2B car , and wire it to your OBD0 harness. so you can plug the OBD2B dizzy into your OBD0 harness. Link to comment Share on other sites More sharing options...
..SSR.. Posted December 4, 2006 Share Posted December 4, 2006 Or he can get a OBD-0 dizzy from HMO. Link to comment Share on other sites More sharing options...
89crxsi1003 Posted December 5, 2006 Author Share Posted December 5, 2006 i dont think they made the b16a2 in a cable tranny or did they? if i was to get this what all else would i need for my swap?? http://hmotorsonline.com/shop/sc2000search...&item=30003 Link to comment Share on other sites More sharing options...
Hatch92 Posted December 5, 2006 Share Posted December 5, 2006 you shouldn't need anything. that's an OBD-0 motor and should bolt right in with minor or any modification at all Link to comment Share on other sites More sharing options...
Kastigir Posted December 5, 2006 Share Posted December 5, 2006 i dont think they made the b16a2 in a cable tranny or did they? if i was to get this what all else would i need for my swap?? http://hmotorsonline.com/shop/sc2000search...&item=30003 You just need a B series cable tranny. Plenty of them around. Link to comment Share on other sites More sharing options...
Hatch92 Posted December 5, 2006 Share Posted December 5, 2006 You just need a B series cable tranny. Plenty of them around. the swap comes with a cable tranny Link to comment Share on other sites More sharing options...
Kastigir Posted December 6, 2006 Share Posted December 6, 2006 the swap comes with a cable tranny Like I actually bothered to click the link. :( Link to comment Share on other sites More sharing options...
89crxsi1003 Posted December 12, 2006 Author Share Posted December 12, 2006 ok so if i was to get this what would i need http://hmotorsonline.com/shop/sc2000search...&item=30003 i was told i would have to rewire the injectors and the dissy???? would the axles fit in the hub w/o and modifying? and i would have to wire the vtech is this as complicated as it sounds?? does anyone have any info on the swap 89 crx si b16a with a cable tranny? or a website? the ecu that comes with this swap is it obd1 or obd0? and whats in my rex now obd0 right? one more thing would i need the harness jumper kit? Link to comment Share on other sites More sharing options...
