shishpanik Posted August 25, 2006 Share Posted August 25, 2006 I just checked out my tires today to see if they needed any inflation since i've had my 06 ex coupe for about 7 months now ( I know, seems a little late to be checking them, but my dad checked them not too long ago and told me "they were fine") and it seems that my two front tires are over by 4 psi (Supposed to be 32 psi and are actually 36 psi, stupid dealership overinflated them). I was wondering what problems does this pose performance/gas mileage/tire-wear wise and if I should just deflate them back to normal or let them stay since thats how they came from the dealer? Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted August 25, 2006 Share Posted August 25, 2006 first of all it is only 4psi..... it will wear out the centers of your tires faster if they are too overinflated. you can change it back Link to comment Share on other sites More sharing options...
xxscaxx Posted August 26, 2006 Share Posted August 26, 2006 it will wear out the centers like pyro said, but also, did you check your tire pressure after driving or when the tires were cold? because there will be a difference in PSI. Link to comment Share on other sites More sharing options...
cranny Posted August 26, 2006 Share Posted August 26, 2006 only 4 psi? lol , 4psi can be twice the difference between win and lose on the track , lol. and on the street , although not as important , is still very. affects the cars handling and tire wear dramatically. the sticker on the dor will tell you exactly what your supposed to run in your tires , regardless if there 195/60/15 , or 205/40/17. you still run 32 lbs in em tops , unless your carrying a bunch of weight in the car. Link to comment Share on other sites More sharing options...
shishpanik Posted August 26, 2006 Author Share Posted August 26, 2006 Both actually, same PSI turned up. Is my fuel economy suffering at all from my tires do you think? Thanks for the info BTW. Link to comment Share on other sites More sharing options...
shishpanik Posted August 26, 2006 Author Share Posted August 26, 2006 Cranny I replied at the same time you did so I didn't get that till now haha. But yeah it's just pretty much me and the car no junk in the trunk and one passenger about 50% of time. The door says 32 psi all round and my fronts are 36 psi, dumb . Link to comment Share on other sites More sharing options...
TS John Posted August 27, 2006 Share Posted August 27, 2006 Generally the difference between a "hot" tire and a "cold" one will be about 4 psi. Not that big a deal. Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted August 27, 2006 Share Posted August 27, 2006 I checked a truck tire once after it just got back after hauling asphalt all day, and It read almost 150.... ~30psi over what they should be running...lol yeah they get hot and expand big time..... Link to comment Share on other sites More sharing options...
