draybook Posted August 14, 2006 Share Posted August 14, 2006 I'm having some trouble with my distributor. I'm driving a 91 CRX HF, with a ZC motor. About once a day, it will either cut off while driving ir not start after having sat for a while. I got the car from my brother in law and he's had that problem for a while. He said something about the distributor "popping" every now and then. Usually, if I give the wires a good reseating it will come back but sometimes it will take about 5-10 mintes to start back up Now, if this is a simple fix then good, if not, what type of distributor will I need to get? Can I get the stock one for that year/model or so I need one from an Integra of the same range? Thanks. Link to comment Share on other sites More sharing options...
whitehatch90 Posted August 24, 2006 Share Posted August 24, 2006 ignition coil Link to comment Share on other sites More sharing options...
Timmythewop89 Posted August 26, 2006 Share Posted August 26, 2006 most likely the coil they can cut out randomly but mostly do it after running for a little Link to comment Share on other sites More sharing options...
