ObieTrice Posted July 28, 2006 Share Posted July 28, 2006 IS it possible to hook up vtec with a p72 obd2 ecu in my integra LS. Link to comment Share on other sites More sharing options...
ObieTrice Posted July 28, 2006 Author Share Posted July 28, 2006 Would this be possible. Link to comment Share on other sites More sharing options...
CleanGSR Posted July 28, 2006 Share Posted July 28, 2006 Your engine doesn't have vtec, so I don't know what you would be hooking up. Are you asking if you can use the ecu, or are you asking if using that ecu will make your car have vtec? Or do you not have the B18A/B any more? Link to comment Share on other sites More sharing options...
ObieTrice Posted July 28, 2006 Author Share Posted July 28, 2006 I have the GSR head Link to comment Share on other sites More sharing options...
CleanGSR Posted July 28, 2006 Share Posted July 28, 2006 Oh, then yes you should have no problem using that ecu. Do you still have the stock GSR IM? If so stick with that ecu, if not get a P28 (I think that's right) You'll need the GSR ecu to make the secondaries work on the GSR IM. Link to comment Share on other sites More sharing options...
ObieTrice Posted July 28, 2006 Author Share Posted July 28, 2006 One of my friends said i ned a obd1 p28 Link to comment Share on other sites More sharing options...
CleanGSR Posted July 28, 2006 Share Posted July 28, 2006 Depends on what year your car is. If it was OBD-1 to begin with, that's true. Is your car pre 96? Link to comment Share on other sites More sharing options...
ObieTrice Posted July 28, 2006 Author Share Posted July 28, 2006 no it is 2002 nm it is 1999 Link to comment Share on other sites More sharing options...
CleanGSR Posted July 28, 2006 Share Posted July 28, 2006 Then stick with the P72 unless you have an aftermarket IM. Link to comment Share on other sites More sharing options...
ObieTrice Posted July 28, 2006 Author Share Posted July 28, 2006 Thanks a lot. Link to comment Share on other sites More sharing options...
CleanGSR Posted July 28, 2006 Share Posted July 28, 2006 No problem. The only other thing to keep in mind is that if you plan to get your car tuned with hondata or something like that, you'll have to convert to OBD-1 and you'll want to use the P28. You'll need an conversion harness too. So, if some sort of tuning is in your near future (which it probably should be with an LS-VTEC) you'll end up having to convert with a P28. Link to comment Share on other sites More sharing options...
cranny Posted July 29, 2006 Share Posted July 29, 2006 there is a P72 obd1 ECU as well hung. which will work instead of buying a P28. he doesnt have to go P28. its just the favorite cause there more plentiful than P72. if your gonna run boost or any EMS(except AEM) youl need obd conversion to 1. i dont know whos idea 2- o2 sensors was but couldnt you just choke the bastard?hahaha Link to comment Share on other sites More sharing options...
CleanGSR Posted July 29, 2006 Share Posted July 29, 2006 I know. I can't even run a test pipe without a check engine light. Not to mention the flexibility OBD-1 has over 2. Link to comment Share on other sites More sharing options...
