Jesse51 Posted June 22, 2006 Share Posted June 22, 2006 I need some advice from out there, my '94 del sol Si won't start. It was running fine, I parked it, set a couple of days then won't start. There is plenty of cranking but nothing else. Fuel pump seems to be working but there is no spark at plug wire when grounded. Thinking maybe it is the ignition control module but don't won't to spend that kind of money without some other input. Any ideas? Link to comment Share on other sites More sharing options...
redcoats1976 Posted June 22, 2006 Share Posted June 22, 2006 when mine did that it turned out to be a bad coil.wqould crank like mad but no try to start. Link to comment Share on other sites More sharing options...
Timmythewop89 Posted June 22, 2006 Share Posted June 22, 2006 theres a dozen things it could be, but i have had the exact scenario you said onece before when the timing chain jumped on my car. it ran fine, i turned it off, went to start it the next day and i got nothing. Link to comment Share on other sites More sharing options...
delsolk20a2 Posted June 30, 2006 Share Posted June 30, 2006 theres a dozen things it could be, but i have had the exact scenario you said onece before when the timing chain jumped on my car. it ran fine, i turned it off, went to start it the next day and i got nothing. if you have a friend that has another motor like yours try changing that distributor, befor you spend the cash , & check the timing Link to comment Share on other sites More sharing options...
93blackH22 Posted July 4, 2006 Share Posted July 4, 2006 believe it or not check your battery strength sometimes when Im out messing around and keep turning off my car it will crank but never start. Then I have to sit there for a little while with the lights off and all that to get it to go again to run off the alternator this might sound kind of noobish but it happens alot for me because either my batt or my alternator blows Link to comment Share on other sites More sharing options...
cranny Posted July 4, 2006 Share Posted July 4, 2006 its your battery cause if your alternator was undercharging the light would be on. and to the guy whos car wont start , its defintely a dizzy issue. and for timmy , need i tell you that hondas dont have timing chains?lol , ok than. and i doubt very much its the timing. ever turn a honda over with the timing way off? youd know it. Link to comment Share on other sites More sharing options...
