JamesPrelude Posted June 13, 2006 Share Posted June 13, 2006 Hi All, Im interested in cleaning the engine bay of my Prelude, but don't know the best way too, or even if it is at all possible?, i have just bought it and am still touching it up. The engine has collected alot of dirt and crap and i just want it too look special. Also very NooB question, i had taken some photos of the engine bay to show you all but i have no idea how to upload them with this thread? how do i do this. Thanks In Advance JamesPrelude Link to comment Share on other sites More sharing options...
cranny Posted June 13, 2006 Share Posted June 13, 2006 go to www.photobucket.com. upload your photos to the site. copy and paste the links it gives you in your message. use bags and ductape and seal off your entire top end. distributor , intake manifold , valve cover. wouldnt hurt to cover your under hood fuse panel either. everything else should be ok. use degreaser and high pressure spray it off over and over till its gone. use common sense when pressure spraying under your hood with things that it could potentially hurt. Link to comment Share on other sites More sharing options...
I heart my prelude Posted July 5, 2006 Share Posted July 5, 2006 Here's a relevant question to this thread. I've bot my 91 lude. just the same as his. can I remove the valve cover and bead blast it to remove all the black? I'm tired of it looking like a funeral under the hood. I'm just worried that the cover might rust after blasting it? Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted July 5, 2006 Share Posted July 5, 2006 1) Warm the engine, then shut it off. 2) Cover the distributer, and you can either cover the alternator and fuse box, or use low pressure spray in those area. 3) Wet the engine with high pressure spray. 4) Spray engine and compartment with Simple Green at full strength (dirty engine) otherwise use 50/50 mix. 5) Let sit for about 5 minutes-use a brush on heavily soiled areas. 6) Rinse with high pressure spray-use low pressure around electrical components. 7) Don't forget the underside of the hood. After rinsing, start the engine and let run until the engine is dry. Go ahead and start wiping down the painted areas-but be careful while the engine is running. 9) After the engine is dry, wipe down and towel dry the areas that you couldn't reach when the engine was running. 10) Finish up with Armor All on hoses and plastic parts and your ready to go. As long as you have no oil leaks, you shouldn't have to clean your engine more than 2 times a year. From teamdelsol.com Link to comment Share on other sites More sharing options...
SexyH22 Posted July 5, 2006 Share Posted July 5, 2006 i just use a degreaser and a pressure washer, im not all that careful about it, but i used to detail cars, so i did them all the time. Link to comment Share on other sites More sharing options...
I heart my prelude Posted July 5, 2006 Share Posted July 5, 2006 Is a pressure washer with 2,000 psi too much pressure? or are to talking about those pressure washers to drive into and pay with quarters? Link to comment Share on other sites More sharing options...
SexyH22 Posted July 5, 2006 Share Posted July 5, 2006 either one just be careful where you spary it on directly. stay away from spraying too hard on anything electrical especcially the dist. carp area. Link to comment Share on other sites More sharing options...
cranny Posted July 5, 2006 Share Posted July 5, 2006 Here's a relevant question to this thread. I've bot my 91 lude. just the same as his. can I remove the valve cover and bead blast it to remove all the black? I'm tired of it looking like a funeral under the hood. I'm just worried that the cover might rust after blasting it? not even , paint stripper on that black paint it melts off like butter on a frying pan. dont forget it is alluminum , so when repainting it , chromate primer (watery yellow stuff)should be used on alluminum before painting it. Link to comment Share on other sites More sharing options...
I heart my prelude Posted July 6, 2006 Share Posted July 6, 2006 Thanks for the advice and not being sarcastic guys. Link to comment Share on other sites More sharing options...
