skateelements16 Posted June 3, 2006 Share Posted June 3, 2006 when i go over bumps n crap or w/e the top like shakes and its kinda loud... any way to tone it down some.? Link to comment Share on other sites More sharing options...
blackdelsol Posted June 3, 2006 Share Posted June 3, 2006 you have to take off the brackets on the car and tighten them. but try lubricating the seals first with silicon. to tighten the seals ( if the silicon doesn't work) you put washers in between the frame and the bracket. 1 1/8th" washer will work for each screw. Link to comment Share on other sites More sharing options...
skateelements16 Posted June 4, 2006 Author Share Posted June 4, 2006 you have to take off the brackets on the car and tighten them. but try lubricating the seals first with silicon. to tighten the seals ( if the silicon doesn't work) you put washers in between the frame and the bracket. 1 1/8th" washer will work for each screw. thx man ill get on that in a few days. Link to comment Share on other sites More sharing options...
