zbyrd Posted April 20, 2006 Share Posted April 20, 2006 I have a civic vx with a d16y8 i want to buy a b16a do i have to get cv axels for the b16a or will the ones from my civic work?? and whitch mounts do i need exactly or can i silicone the ones i have ? Link to comment Share on other sites More sharing options...
mountaindewguy Posted April 20, 2006 Share Posted April 20, 2006 b series engine = b series axels. Link to comment Share on other sites More sharing options...
zbyrd Posted April 20, 2006 Author Share Posted April 20, 2006 What about the mounts? Link to comment Share on other sites More sharing options...
civicminded10 Posted April 20, 2006 Share Posted April 20, 2006 What about the mounts? Get hasport motor mounts Link to comment Share on other sites More sharing options...
jason5.5 Posted April 20, 2006 Share Posted April 20, 2006 Get all the mounts from a 94 up integra as the hasport or avid racing mounts STILL leave you needing the stock integra mounts.Also from a 93-97 Del sol si (if it was equiped with a b-series motor) you should get the ac bracket and the rear tranny mount the rear tranny mount from the integra may need to be modified slightly to work.Pretty much all this info and more can be found under swaps... Link to comment Share on other sites More sharing options...
JDM_Hamster Posted April 20, 2006 Share Posted April 20, 2006 Why not just get the 1999 Civic Coupe Si motor mounts... to make your search for the motor mounts go with the Hasport Motor maounts... Oh and Del Sol Si's have D series motors, you're thinking about Del Sol VTEC that comes with a B16A3... Link to comment Share on other sites More sharing options...
zbyrd Posted April 26, 2006 Author Share Posted April 26, 2006 i also need the shift linkedge and the linkedge for the trottle right Link to comment Share on other sites More sharing options...
cranny Posted April 26, 2006 Share Posted April 26, 2006 throttle cable will be fine. shift linkage will most likely also work , maybe minor mods to it. Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted April 26, 2006 Share Posted April 26, 2006 http://www.hondaforums.com/index.php?showtopic=13533 if you used the search button it tells you everything you need to know, even says how to wire it, Link to comment Share on other sites More sharing options...
Hatch92 Posted April 30, 2006 Share Posted April 30, 2006 u will need b series axles, shifting linkage, and mounts. Link to comment Share on other sites More sharing options...
