Benji Posted April 20, 2006 Share Posted April 20, 2006 I am hoping that someone has maybe had some experiance with this. We just got in an '01 CL type S at work, and I want to see if I can slap the 260hp 3.2 type S into my 200hp 3.0 '01 Accord. I have already swapped the exhaust over, just don't know about the rest of it... namely the ECM and wiring... I know that the Accord has a 4 speed AT and the CL has a 5 speed AT but I'm pretty sure the bellhousing bolt pattern is the same. Can anyone help? Am I nuts for wanting to pimp my V6 Accord? Link to comment Share on other sites More sharing options...
TLontheDL Posted April 20, 2006 Share Posted April 20, 2006 You are nuts.. It MAY fit with a little adjustment b/c the 3.2 is a little larger of an engine. Also the engine is a lot more heavier so you'll have to beef up your suspension a bit, otherwise your front end might sag. Link to comment Share on other sites More sharing options...
