Carob Posted April 17, 2006 Share Posted April 17, 2006 Can anyone tell me the procedure for turning off the regular schedule maintenance light thing? Thanks! Link to comment Share on other sites More sharing options...
CleanGSR Posted April 17, 2006 Share Posted April 17, 2006 Probably depends on the car, but my car has a button under the dash on the driver's side. I believe you just hold that button in while you turn on the ignition and it reset's. If your is the same as mine then I think it tells the procedure in the manual. Link to comment Share on other sites More sharing options...
Carob Posted April 17, 2006 Author Share Posted April 17, 2006 Probably depends on the car, but my car has a button under the dash on the driver's side. I believe you just hold that button in while you turn on the ignition and it reset's. If your is the same as mine then I think it tells the procedure in the manual. Oh, sorry. I forgot this was a multiple car forum. It would be on a 2006 RSX-S. Link to comment Share on other sites More sharing options...
CleanGSR Posted April 18, 2006 Share Posted April 18, 2006 I'd bet you have the little button under the dash like mine. Since mine is a 2000 Integra GSR, I would think they might be similar. Let us know if that works. Link to comment Share on other sites More sharing options...
Carob Posted April 18, 2006 Author Share Posted April 18, 2006 I'd bet you have the little button under the dash like mine. Since mine is a 2000 Integra GSR, I would think they might be similar. Let us know if that works. I don't know if this is true or not but I got this info from another source... You can reset the maintenance light if you'd like by holding down the knob that changes your tripmeter, then turning the ignition to the 2 position. (on, but don't start the car) Keep the knob down until light stops flashing, (usualy around 10 sec or so) and it should be reset. Link to comment Share on other sites More sharing options...
ap1drvr Posted April 18, 2006 Share Posted April 18, 2006 I don't know if this is true or not but I got this info from another source...You can reset the maintenance light if you'd like by holding down the knob that changes your tripmeter, then turning the ignition to the 2 position. (on, but don't start the car) Keep the knob down until light stops flashing, (usualy around 10 sec or so) and it should be reset. That's how I reset my S2000, I can't confirm if that's the correct way for your RSX-S... that's a common way to reset the lights & works for other manufacturers also. Your owners manual doesn't say how to do it? Link to comment Share on other sites More sharing options...
CleanGSR Posted April 18, 2006 Share Posted April 18, 2006 Mine doesn't have a digital odomoter so that's probably why mines different. Give it a shot and see if that does it. Link to comment Share on other sites More sharing options...
Carob Posted April 20, 2006 Author Share Posted April 20, 2006 http://www.acuraworld.com/forums/showthread.php?t=36977 Link to comment Share on other sites More sharing options...
