Akil1931 Posted March 11, 2006 Share Posted March 11, 2006 Check this, I have been asking around but am not sure what it is. My 99 Accord (4 Cyl) could be running smooth but then sometimes, when I begin to slow down and/or come to a complete stop, my car begins to sputter and then it will turn off. I would then have to put it in neutral and turn it on again. As soon as it does that, the check engine light goes on, but then it will stop and the check engine light will go off. Some people have told me that it could be the alternator, but I want more advice. It also happens if I put the car in neutral or park when I feel the car sputtering. It will turn off. Ima take it to a mechanic this week, but wanted to see if anyone knew what it could possibly be. Thanx. Akil Link to comment Share on other sites More sharing options...
cranny Posted March 11, 2006 Share Posted March 11, 2006 unless your battery is dying on you i doubt its the alternator. besides if your alternator was bad your battery/alternator light would come on not your engine light. whenever your engine light comes on your ecu will store a certain code that tells you what the possible problem could be. giving the fact your engine light is comming on leads me to believe its a sensor of some sort. im not 100% sure, since you said your engine light comes on than goes off, if your ecu will hold the codes even though the light goes back off. but like i said if you can get that code its givin you than youl know at least the vicinity of the prolem. Link to comment Share on other sites More sharing options...
Akil1931 Posted March 21, 2006 Author Share Posted March 21, 2006 OK, So I took my car to the mechanic and he connected the machine and it spit out the code P0171 (System Adaptive Fuel too lean). What I was told that means is that it is either the oxygen sensors or the fuel pressure regulator (I called the Honda dealer and he looked it up for me). What I am gonna go is change both the primary and secondary O2 sensors and if needed later on, change the fuel pressure regulator. Just wanted to let you all know of this in case anyone goes through this problem and/or spits out that code. Thanx all. Akil Link to comment Share on other sites More sharing options...
InfinitePrelude Posted March 22, 2006 Share Posted March 22, 2006 hmm most honda o2 sensors only tend to get lazy after 8 years. but should still work ok for 10 years or more. strang that is giving in so soon Link to comment Share on other sites More sharing options...
CleanGSR Posted March 22, 2006 Share Posted March 22, 2006 Why would the amount of years have an affect? It would seem more like the mileage on the motor would play a role in how long they lasted. Link to comment Share on other sites More sharing options...
cranny Posted March 22, 2006 Share Posted March 22, 2006 i agree hung. even if the car is only 4 years old , if it got 400,000 miles on it than , lol. Link to comment Share on other sites More sharing options...
InfinitePrelude Posted March 22, 2006 Share Posted March 22, 2006 yeah it depends though. if you done only 9 miles in 10 years your still gonna have the say problem as someone that done 100,000 miles in 9 days. (exaduration) but o2 sensor shouldn't be effected to much by the amount of miles, ok yes a little but that depends on alot of facters. Link to comment Share on other sites More sharing options...
