Blackbean Posted February 1, 2006 Share Posted February 1, 2006 My engine check light is on.I seached and found out that I can put the codes by putting a paper clip in the blue connector on the passender side,but I can,t get the blue connector out of the green boot.Is there a trick. Also, how often do the oxygen sensors need replacing?I replaced both already and only have 100,000 kms/60,000 miles on my 98 civic hb. Link to comment Share on other sites More sharing options...
cranny Posted February 1, 2006 Share Posted February 1, 2006 not sure what kind of car were talkin about from now on i wish people would start given that one piece of crucial evidence , hahaha. Link to comment Share on other sites More sharing options...
Blackbean Posted February 2, 2006 Author Share Posted February 2, 2006 Come on, I,m having problems getting the blue connector out of the green plastic boot(I don,t want to pull the 2 wires out) Its a 98 civic. I think one of the oxygen sensor is bad. Link to comment Share on other sites More sharing options...
CleanGSR Posted February 2, 2006 Share Posted February 2, 2006 Just go to Autozone. They will pull your codes for free and probably even tell you what the codes mean. Much simpler. Link to comment Share on other sites More sharing options...
cranny Posted February 2, 2006 Share Posted February 2, 2006 its very simple to get the codes , id recommend buyin a haynes manual for everyone actually. but find the harness under passenger side for your obd . theres 2 wires you need to cross with ignition off , once wires are crossed turn ignition on and pow engine light will flash. Link to comment Share on other sites More sharing options...
