Hybrid95Civic Posted February 1, 2006 Share Posted February 1, 2006 I need an ECU for a D15B7 so I can make it manual so will I have to change the intake and injectors or can I keep it the same? ANd What will I have to change to make it a Manual if it is an automatic???? I have a tranny that fits a D16Y8 I was wondering if that would work? SO can Anybody Help me out here Just starting in the import game and loving it but not total understand that will mismatch with different engines!! Out HYBRID Link to comment Share on other sites More sharing options...
cranny Posted February 1, 2006 Share Posted February 1, 2006 theres info about this already in other threads. Link to comment Share on other sites More sharing options...
Hybrid95Civic Posted February 1, 2006 Author Share Posted February 1, 2006 I need to buy a ecu for the manual trany and motor Link to comment Share on other sites More sharing options...
cranny Posted February 3, 2006 Share Posted February 3, 2006 id have to say no , ecu will work fine,all you need is mechanical differences. you need axels , the front and rear mounts might be a bit different(was in a 90 swap i did from auto to man, had to change where mount bolted to subframe as well and it really sucks). shift linkage and shifter assembly. also you need pedal assembly and clutch cable(hole should be in firewall already). all engine wiring should be the same. Link to comment Share on other sites More sharing options...
ishkur Posted February 3, 2006 Share Posted February 3, 2006 if your manual is off the same block, you don't need to worry about the injectors and rail, but you do need to get the ecu off of a manual transmission from the same kindof car because a automatic ecu is only designed for an automatic (if you don't swap the ecu you'll hit 80 m.p.h. and your gov. will kick in and shut down the motor) Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted February 6, 2006 Share Posted February 6, 2006 u need to find a harness of another manual in other words,,the automatic harness will not work right Link to comment Share on other sites More sharing options...
