k4rts Posted January 29, 2006 Share Posted January 29, 2006 i dont know if its the pedal or not, but when the engine is cold, the gas pedal is "smooth". when it heats up, the gas pedal gets harder to push, and when it finallly grabs..the engine revs to like 4000 rpm then it makes it look like i dont know how to drive the manual lol. whats wrong here Link to comment Share on other sites More sharing options...
CRXSSIVE Posted January 29, 2006 Share Posted January 29, 2006 pop the hood & inspec the throttle cable, spray some wd40 on the spring that the cable hooks onto which is located on the intake manifold it could possibly be sticking. Link to comment Share on other sites More sharing options...
cranny Posted January 30, 2006 Share Posted January 30, 2006 id say its the throttle body itself . fluid film all the moving parts. Link to comment Share on other sites More sharing options...
guyevans Posted January 30, 2006 Share Posted January 30, 2006 i am having the same problem and i just changed the intake manifold and throttle body to a skunk2 and the throttle body is 70 mm's i have change sensors and idle control valve and havent figured it out yet Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted January 31, 2006 Share Posted January 31, 2006 try turning the pivot right where the cable attaches to the throttle body...find out if its the cable or throt body.. Link to comment Share on other sites More sharing options...
Bahamacivictuner Posted January 31, 2006 Share Posted January 31, 2006 Nothing is scarier than having your gas pedal jamming @ fullthrottle, goin 70 down a 25mph street, with your girlfriend in the car and you have only had the car for 3 days. The Idiots @ the dealer pulled the carpet behind the accel, and the pedal got caught behind it :S Link to comment Share on other sites More sharing options...
cranny Posted January 31, 2006 Share Posted January 31, 2006 pull the intake off the engine visually inspect the butterfly valve inside the throttlw body is it dirty oily , try some intake manifold/throttle body cleaner. Link to comment Share on other sites More sharing options...
