hurleyint1386 Posted January 13, 2006 Share Posted January 13, 2006 im just wondering, how difficult is it to replace a clutch? i just bought an 89 crx si at 160k miles, and the clutch is starting to go and i was quoted at $873.28 for the clutch kit and installation. if i bought a clutch for around $200 would i be able to put it in myself? because $615 is a lot of money for the installation alone. Link to comment Share on other sites More sharing options...
CleanGSR Posted January 13, 2006 Share Posted January 13, 2006 You have to drop the tranny to install a new clutch and it's not an installation for a novice. That sounds like a high price for labor though. I'd definately check with some other shops if I was you. Link to comment Share on other sites More sharing options...
hurleyint1386 Posted January 13, 2006 Author Share Posted January 13, 2006 That quote was from Goodyear, are there any other big name shops that usually have good prices? I just don't want to get screwed over by good year. They told me it would cost $90 to flush and fill the manual transmission fluid, and I went to Jiffy Lube and it cost $34 Link to comment Share on other sites More sharing options...
ap1drvr Posted January 13, 2006 Share Posted January 13, 2006 That quote was from Goodyear, are there any other big name shops that usually have good prices? I just don't want to get screwed over by good year. They told me it would cost $90 to flush and fill the manual transmission fluid, and I went to Jiffy Lube and it cost $34 $90! Holy sh*t, it only takes 2 qts. of fluid. The Honda MTL is maybe $10-12 for 2qts. & it's easier than changing oil. The GM Synchromesh fluid would run you about $16 for 2 quarts. Go to a smaller local shop & get a quote. Clutch replacement isn't a newbie job, if you have the proper tools & automotive skill then yes. That labor quote is absurd. Link to comment Share on other sites More sharing options...
hurleyint1386 Posted January 13, 2006 Author Share Posted January 13, 2006 $90! Holy sh*t, it only takes 2 qts. of fluid. The Honda MTL is maybe $10-12 for 2qts. & it's easier than changing oil. The GM Synchromesh fluid would run you about $16 for 2 quarts.Go to a smaller local shop & get a quote. Clutch replacement isn't a newbie job, if you have the proper tools & automotive skill then yes. That labor quote is absurd. yea, i really would like to learn about cars and do things myself, but a new clutch is a little too much to start. id like to get a beater car and take it apart and work on it. yea, 90 is way too much for a transmission fluid change. ill shop around and see if i can find someone who can do it for cheaper. Link to comment Share on other sites More sharing options...
