baludoy Posted November 30, 2005 Share Posted November 30, 2005 The brake warning light stays on. Brake fluid level is OK. What may be the problem? Thank you. Bal Link to comment Share on other sites More sharing options...
TLontheDL Posted November 30, 2005 Share Posted November 30, 2005 it usually shows up in cold weathers for some reason. does it turn off after you drive it for awhile? Since you bought the car, have you changed out the brake pads? For more details, check your owners manual as well. Link to comment Share on other sites More sharing options...
Humphries Posted November 30, 2005 Share Posted November 30, 2005 might be air in the lines. bleed the brakes and refill brake fluid. or if the brake pads have been changed then you might just have to reset the computer by taking the battery terminals off for about 5 minutes then you will be okay. Link to comment Share on other sites More sharing options...
ademan Posted December 6, 2005 Share Posted December 6, 2005 threra two warinig lamps: 1. hand brake ( looks like (!) ) - check fluid 2. lamp with the title "brake" - check red stop lamps. IMHO Link to comment Share on other sites More sharing options...
Humphries Posted December 7, 2005 Share Posted December 7, 2005 do your brakes still work? Link to comment Share on other sites More sharing options...
ademan Posted December 7, 2005 Share Posted December 7, 2005 do your brakes still work? it seems no, he's been keeping silense fora long time ))))))) Link to comment Share on other sites More sharing options...
