dawrenn Posted September 10, 2005 Share Posted September 10, 2005 I have a 99 Civic with a 99 GSR engine converted to OBD-1 using an OBD-1 P72 ecu. I was talking to my friend and he says he thinks I have weak VTEC. He says that could be caused by the secondary butterflies not working properly. I mean I can hear them kick in everytime I take it to high RPM's so to me they are working properly. Is there anyway I can find out if they are not working right or if I have weak vtec? Link to comment Share on other sites More sharing options...
SexyH22 Posted September 11, 2005 Share Posted September 11, 2005 why did you convert to OBD1? Link to comment Share on other sites More sharing options...
dawrenn Posted September 11, 2005 Author Share Posted September 11, 2005 why did you convert to OBD1? I converted to OBD1 b/c the shop already had my car long enough and I wanted it back and they said that an OBD-2 GSR ECU would not work with my stock harness so I had to either use an Si ECU which would take away the secondary runners or convert to OBD1 so I said fawk it and converted to OBD-1. After I did that I talked to the place I bought the engine from and they said I could use an OBD-2 GSR Ecu but it had to be specialy made. I am still waiting on that. Link to comment Share on other sites More sharing options...
..SSR.. Posted September 12, 2005 Share Posted September 12, 2005 There is no such thing as weak VTEC. It kicks in, end of story. If the butterflies are opening, then that is not the problem. Answer, your friend is an idiot. Link to comment Share on other sites More sharing options...
dawrenn Posted September 12, 2005 Author Share Posted September 12, 2005 There is no such thing as weak VTEC. It kicks in, end of story. If the butterflies are opening, then that is not the problem. Answer, your friend is an idiot. If he is an idiot how did he do this: Its a TSX/Type S Hybrid EG EDIT: Read this http://www.honda-tech.com/zerothread?id=1290688 Link to comment Share on other sites More sharing options...
..SSR.. Posted September 12, 2005 Share Posted September 12, 2005 Any monkey can swap an engine, and put a head on an engine. Link to comment Share on other sites More sharing options...
hellyeah!! Posted September 16, 2005 Share Posted September 16, 2005 what kind of engine is that? why is the intake in the front? did they turn the engine around? Link to comment Share on other sites More sharing options...
dawrenn Posted September 16, 2005 Author Share Posted September 16, 2005 what kind of engine is that? why is the intake in the front? did they turn the engine around? Its a k24 engine. THe intake is suppose to be like that. Link to comment Share on other sites More sharing options...
