xalexjx@yahoo.com Posted February 20, 2006 Share Posted February 20, 2006 1995 honda civic hb, steering wheel shakes from 73mph on have had all my tires balanced, put on strait.. not sure if its a wheel bearing or axle? Link to comment Share on other sites More sharing options...
cranny Posted February 20, 2006 Share Posted February 20, 2006 if your absolutely sure there balanced properly(most places absolutely blow at balancing wheels cause they static balance them and its not proper), than you may have a warped rotor causing your prolem. a warped hub assembly(which most likely youd feel before 70mph), or a warped wheel perhaps .if tires are old it could be a broken or damaged steel belt in your tire. if your wheel bearing was bad youd hear it howling at that speed. and if your axle was bad enough that it was causing vibration youd most likely not feel it in the steering wheel but in the car itself. Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted February 23, 2006 Author Share Posted February 23, 2006 i have bn winter rims and tires, replaced the front rotors and pads a month ago,(it did it before that) has a new front left wheel bearing, also it makes my glove box rattle i noticed, also iv balanced the tires on my balncer in my garage 3 times and its still doing it, also it does it on my summer rims which i know were balanced Link to comment Share on other sites More sharing options...
cranny Posted February 23, 2006 Share Posted February 23, 2006 sounds like you may have a worn out hub , are you static balancing the wheels? its a 95 so i had the same prolem with my 91 hatch. the dam thing shimmied for the last 3 years i owned it no matter what i fixed. i chalked it up as a slightly warped hub givin the fact i replaced eberythin else , haha. id say its a hub dude. even the haynes manual for your car(which i looked at for ya), says it could be a warped or damaged hub. new brakes , fresh balance? i mean whats left?hubs id say. Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted February 23, 2006 Author Share Posted February 23, 2006 thanks, ill look into that Link to comment Share on other sites More sharing options...
cranny Posted February 23, 2006 Share Posted February 23, 2006 np dude let us know im curious myself given the fact i never did fix the shimmy in my 91 civic , but the only thing i never replaced was the hubs so. Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted February 23, 2006 Author Share Posted February 23, 2006 im gonna replace the wheel bearings,, ill tell you if they fix it,,also it only has 60,000 miles on it..they should last till at least 100k but who knows,,, Link to comment Share on other sites More sharing options...
cranny Posted February 23, 2006 Share Posted February 23, 2006 doesnt really matter the age though , cause it only takes one big bump and thats it never the same again. i was drivin an older guy home from work at dawn with my civic you see below . they had a strip tore out of the road from one side to the other and it was twilight i couldnt see how bad it was. hit doin like 50km/h or 30m/h and it bent 2 of my 17's and threw my allignment off(bent somin). wasnt impressed at all in fact i was cursin and swearin like a madman in this nice neighborhood at about 630 am. wasnt a good scene.hahaha. thats the worst wheel in the pic. <a href="http://img138.imageshack.us/my.php?image=im001036a8ms.jpg" target="_blank"><img src="http://img138.imageshack.us/img138/1594/im001036a8ms.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a> Link to comment Share on other sites More sharing options...
JDM_Hamster Posted February 23, 2006 Share Posted February 23, 2006 I had almost the exact same problem but it was my tire pressure and balancing because they messed up when balancing them, so like the saying goes "If you want it done right, Do it yourself." but its fine now... you also might want to check the inside and outside of your wheels because you might have bent your wheel or there might have been too much pressure on the inside of the wheel and it might have bent...( happened to my stepdads truck, yes i know there is a wieght difference in a truck and a civic) If its not any of the things i said, i have no idea at all...-_- Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted February 23, 2006 Author Share Posted February 23, 2006 they are bn rims less then a week old..plus my summer rims did it, its not the balanceing because i have done it my self 3 diif times w/ these rims and my old rims...its most likely the wheel bearings, Link to comment Share on other sites More sharing options...
xxscaxx Posted February 24, 2006 Share Posted February 24, 2006 when my wheel bearing was bad on my del sol, it made a noise, never shook my car. and it didnt do it all the time. you might have a warped rotor if they werent put back on right or in the right way. Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted February 24, 2006 Author Share Posted February 24, 2006 no im posotive i put the rotors on the right way although i will check, Link to comment Share on other sites More sharing options...
JDM_Hamster Posted February 24, 2006 Share Posted February 24, 2006 i dont think that the steering wheel would shake if it was a rotor, that should only be when you are braking... it could possibly be the bearings (thats going to be a pain in the ass)... Link to comment Share on other sites More sharing options...
cranny Posted February 26, 2006 Share Posted February 26, 2006 its not the bearings , bearings howl not shake. and yes warped rotors can make your wheel shake even though your not braking. dude im gonna tell you this and save you money if you listen , in order for them to put front wheel bearings on dude they have to seperate your hubs from your spindles. im tellin you its most likely a hub cause it happens in hondas alot. now if you go put wheel bearing on and dont change the hubs that means that youl have to pay someone to seperate them again. as far as the brake rotors not bein installed right well as long as hub was cleaned and rotor seated with no play on it than id say they were put on right. you got warped hubs dude or hub.can you remeber when it started doin it or did it always do it? Link to comment Share on other sites More sharing options...
DJB98LX Posted February 26, 2006 Share Posted February 26, 2006 I agree on the bearing thing!! they make a whine or howl or what ever you want to call it!! If a bearing was bad enough to actually shake, don't you think there would be a horrible grinding sound along with it?? Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted February 27, 2006 Author Share Posted February 27, 2006 i have all the tools needed to pull of hubs, ball joints and spindles, im just going to take it apart, after i order the complete hubs and wheel bearings, and ill se whats wrong an install it..ill let you know when i do it, if i get time to do it in the next two weeks Link to comment Share on other sites More sharing options...
ap1drvr Posted February 27, 2006 Share Posted February 27, 2006 Did you rule out ball joints, bushings & alignment? FYI a bearing will make the car shake. I just changed mine this weekend, it started as the typical humming, then went to vibration that can be felt through the pedals, then finally it could be felt in the steering wheel and eventually began pulling right. I knew the bearing was bad from when I did the balljoints, tie rods ends and bushings on that side, I just put it off until it got really bad. My 93 Civic shook from 70-80mph then smoothed out, my 94 now does the same thing. I gave up on my 90 hatch, it had a shake in the right front that drove me nuts for over a year & I gave up checking & replacing crap. Link to comment Share on other sites More sharing options...
cranny Posted February 27, 2006 Share Posted February 27, 2006 dude please dont jump in without reading the rest thats been said. only thing that can make your wheel shake is something thats turning with the wheels and out of balance , period. Link to comment Share on other sites More sharing options...
ap1drvr Posted February 27, 2006 Share Posted February 27, 2006 Sorry...you are apparently the know all, I apologize for second guessing your vast knowledge. I read the post. So suspension has nothing to do with a shaking wheel? Since the only thing that can make the wheel shake is something that turns? Then what does the bearing do dipcrap?... oh yeah...it turns. That's what bearings do, I figured you had that kind of advanced technology figured out by now I'm wrong anyhow but a bad bearing is 'out of balance', take the wheel off a car with a bad wheel bearing, pull the rotor and what does it do when you move the front hub? IT WOBBLES ALL OVER THE DAMN PLACE, seeing how the lug nuts hold the wheel to the front hub any sliver of common sense would tell me the wheel would probably shake too. How you damage the hub without hurting the bearing is a new one to me since the bearing is pressed onto the hub, which then is pressed into the knuckle. My wheel shook, I changed the bearing....NOTHING else and it stopped. Did you even read my post? I'm pretty sure I mentioned that. So if you have a bad front lower arm to chassis bushing that allows the arm to shift while driving you won't feel that through the wheel....whatever. Sorry for giving my input, cranny is the suspension god. xalexjx@yahoo.com fell free to consider my thoughts but you're apparently better off having the wheel balanced over & over again & never having to replace any suspension parts since they don't rotate or have any effect on driveability. Link to comment Share on other sites More sharing options...
Verbal Killa Posted February 28, 2006 Share Posted February 28, 2006 Hey im having the exact same problem. while im drivin an hit around 50-60 thoe. the whole car starts vibrating an shaking. glove compartment shakes too. sterring wheel etc. an its annoying as fawk. u get used too it but its annoying. so if u fix this problem tell me how u did it. i also had my wheels balanced. i herd it was an Alignment thoe? i havent done that yet. on ur car does it like.. the front tire start shaking? when u hit a certain milage? Link to comment Share on other sites More sharing options...
93ZCivic Posted February 28, 2006 Share Posted February 28, 2006 :drew: whatabout alignment?? Link to comment Share on other sites More sharing options...
InfinitePrelude Posted February 28, 2006 Share Posted February 28, 2006 likely cases... tyre problems (i.e. small lumps weak spots etc) rim damage brake disc balance / alignment or (see if the disc is flat) ball joint loose wheel barring whats it like if you brake hard from 40+ mph does it wobble? Link to comment Share on other sites More sharing options...
JDM_Hamster Posted March 1, 2006 Share Posted March 1, 2006 likely cases...tyre problems (i.e. small lumps weak spots etc) rim damage brake disc balance / alignment or (see if the disc is flat) ball joint loose wheel barring whats it like if you brake hard from 40+ mph does it wobble? yeah i already said that it might be a tire or wheel problem but he said that it did it with his stock rims also... it could be a ball joint or loose wheel bearring... Link to comment Share on other sites More sharing options...
cranny Posted March 1, 2006 Share Posted March 1, 2006 im only gonna say it one more time , an alignment bein off can NOT make your car shake. its definitely hub or wheel issue. dumass on the other post was rippin me talkin about bearings causin the prolem , gee youd think if a wheel bearing was bad enough to make the car shimmy it would at least howl and make noise eh?? maybe not. if it shakes with both sets of wheels , than deductive reaosning tells me thats it somin to with the car not the wheels in this particular case. he says he replaced the brakes so well eliminate them. if it was a bearing im sure hed hear it and have a clue thats what it was(which i doubt). im stickin to my guns its a hub. as far as joints goes , if he does have well say loose lower balls or tierods , than youl feel the shakin more but theres still somin turning out of balance thats creating the shimmy. Link to comment Share on other sites More sharing options...
ap1drvr Posted March 1, 2006 Share Posted March 1, 2006 im only gonna say it one more time , an alignment bein off can NOT make your car shake. its definitely hub or wheel issue. dumass on the other post was rippin me talkin about bearings causin the prolem , gee youd think if a wheel bearing was bad enough to make the car shimmy it would at least howl and make noise eh?? maybe not. if it shakes with both sets of wheels , than deductive reaosning tells me thats it somin to with the car not the wheels in this particular case. he says he replaced the brakes so well eliminate them. if it was a bearing im sure hed hear it and have a clue thats what it was(which i doubt). im stickin to my guns its a hub. as far as joints goes , if he does have well say loose lower balls or tierods , than youl feel the shakin more but theres still somin turning out of balance thats creating the shimmy. I'm curious to know what kind of magic is involved to damage the hub & not effect the bearing. I'm not saying your wrong, your just so quick to jump on other people's crap who second guess you, the fact is the hub is pressed into the bearing. http://media.honda.co.uk/car/owner/media/m...l/pdf/18-10.pdf http://media.honda.co.uk/car/owner/media/m...l/pdf/18-14.pdf I don't recall ever saying that a bad bearing didn't make noise. Link to comment Share on other sites More sharing options...
