hondahead Posted September 21, 2002 Share Posted September 21, 2002 I have two questions the first is are the b18a and the b18c blocks the same and the second is what parts in the bottom end or block are different in a b18a then in the b18c? matt Link to comment Share on other sites More sharing options...
EGRacer Posted September 21, 2002 Share Posted September 21, 2002 ummm... i should know this but kinda dont right now just woke up. ask toda Link to comment Share on other sites More sharing options...
Toda Party Posted September 22, 2002 Share Posted September 22, 2002 I have two questions the first is are the b18a and the b18c blocks the same and the second is what parts in the bottom end or block are different in a b18a then in the b18c? matt 1 - no 2 - b18a is the same as the b18b...non vtec, 9.2:1 compression ratio, 81.0mm bore (same in all b-series motors except the b20 which has an 84.0mm bore), 89.0mm stroke, no oil squirters... b18c - 87.2mm stroke, oil squirters, 10:1 cr for gsr, 10.6:1 for US and Canadian ITR, 11:1 for JDM ITR, block girdle, different oil and water pumps Link to comment Share on other sites More sharing options...
EGRacer Posted September 24, 2002 Share Posted September 24, 2002 thanks toda i was cornfused about that Link to comment Share on other sites More sharing options...
