cclpickle Posted December 31, 2004 Share Posted December 31, 2004 my car is missing and ive got new plugs wires cap and rotor and a new distributor and my ecu blinks 15 times i looked in the book and it said ignition output sinal could this be my ecu . help!!!!!! Link to comment Share on other sites More sharing options...
burplecrx90 Posted April 7, 2005 Share Posted April 7, 2005 CODE 15 is indicated. It is highly likely a fault relating with the ignition output signal/igniter module. (It may take about 20 seconds of cranking to set off the code) A faulty igniter module also gives the same hot hard starting symptoms as a faulty main relay. The difference is that for the igniter module, the fuel pump can be heard working after the ignition is turned on, during when the check engine light lights up for about 2 seconds. Link to comment Share on other sites More sharing options...
s.wilson Posted April 14, 2005 Share Posted April 14, 2005 my car is missing I hope you find it soon!! hahaha....I'm a jokester!!! Link to comment Share on other sites More sharing options...
