rudelude22 Posted December 9, 2004 Share Posted December 9, 2004 Well i just recently bought another 4th gen lude, but come to find out that the crank was bad in it so i swapped out the motor. and what the hell i thought honda cranks were stout, anyways now my car surges all the time like it idles between 1-2,000rpm so if you guys know why this would happen let me know, and dont say vacuum lines i checked all those and the ecu hookups im good there, and theres no check engien light on, what do i do? thanks Link to comment Share on other sites More sharing options...
SexyH22 Posted December 9, 2004 Share Posted December 9, 2004 could be a bad iacv. or try bleeding your collent lines, a bubble can cause that too. most likely iacv or fast idle valve tho. Link to comment Share on other sites More sharing options...
civlude_h23vtec Posted December 10, 2004 Share Posted December 10, 2004 Well i just recently bought another 4th gen lude, but come to find out that the crank was bad in it so i swapped out the motor. and what the hell i thought honda cranks were stout, anyways now my car surges all the time like it idles between 1-2,000rpm so if you guys know why this would happen let me know, and dont say vacuum lines i checked all those and the ecu hookups im good there, and theres no check engien light on, what do i do? thanks yep double check that the IAC valve electrical connector is connected it located right on the intake manifold also check the fast idle thermo valve located on the throttle body thats most likely the problem. To check that: 1.remove air intake 2.start the engine 3.put your finger over the lower port in the throttle body and make sure there is air flow with the engine COLD. If not replace the valve. 4.warm the engine up till radiator fan comes on. 5.check that the valve is completely close if not air suction will be felt 6.check coolant level add if it is low 7.bleed any air from system to do that you must loosen the nut over the thermostat hosing until you see coolant running out. try that and your problem should go away Link to comment Share on other sites More sharing options...
rudelude22 Posted December 20, 2004 Author Share Posted December 20, 2004 hey thanks alot im going to try that tomorrow Link to comment Share on other sites More sharing options...
stuckmofo Posted December 20, 2004 Share Posted December 20, 2004 a few of us that have bought motors have had bad idle contol motors Link to comment Share on other sites More sharing options...
