SW_Teki Posted August 14, 2002 Share Posted August 14, 2002 My 1988 Accord has just recently started having headlight troubles. At first I had low beam only and if I activated high beam the lights would quit when I switched back to dim...turning them off (allowing headlights to go down) and back on usually brought things back. Now however ONLY the brights will work and no amount of playing with the switch seems to help. :( Any Ideas? Thanks in Advance! Teki Link to comment Share on other sites More sharing options...
Trepid Posted August 14, 2002 Share Posted August 14, 2002 you may have a stripped wire somewhere that is causing a short... my dad had the same problem in his truck and it was just a simple wiring fix, but to find the wire was a task... but then again that was a ford... Link to comment Share on other sites More sharing options...
SW_Teki Posted August 14, 2002 Author Share Posted August 14, 2002 Heh...well, I would hope Honda does a much nicer factory wiring job than Ford but one never knows...Time to start tracing things back looking for a bare spot I guess... Anyone else have any suggestions? Link to comment Share on other sites More sharing options...
EGRacer Posted August 16, 2002 Share Posted August 16, 2002 hell ah man hondas wiring is long big and lots of crap that dont make sense Link to comment Share on other sites More sharing options...
