Posted
I'm working on an 05 Accord Hybrid 3.0. It has a unique tensioner that I can't find. It looks like the OE number is 31170RCJA01. However it was discontinued. The aftermarket lookup is for a different tensioner with a larger center bolt hole and a greater distance to the side hole to keep it from spinning. Does anyone have a source or information on what they are using to replace it? The two bolts currently used are 10mm heads. It only drives the A/C compressor. There PS is electric. No alternator. Water pump drivin by timing belt.
