Posted
Long story short I hit a curb hard on the driver side and now the tire is pushed back a good bit. Along with the other stuff wrong with the car is it worth it to fix or just part out? Here is the list of parts needing to replace so far: wheel bearings, tie rods, coil over body (driver side), passenger front spindle(keeps coming loose), torque converter (clunky shifts), and the subframe looks bent (axle is hitting subframe when jacked up). seems like its time to part it out but to fix everything except the trans would be between $380-$700 depending on how much i could get a subframe for. thoughts?
