Honda guy Casey Posted December 25, 2023 Share Posted December 25, 2023 My 2002 Honda Accord 2.3 EX has a code of P1381. It has intermittent loss to the CMP sensor when it reaches 3000 RPMs after it has fully warmed up. when I let off the gas, it allows the vehicle to shift and drives fine otherwise. I have replaced the distributor and spark plugs and alternator voltages good. Quote Link to comment Share on other sites More sharing options...
Honda guy Casey Posted December 25, 2023 Author Share Posted December 25, 2023 21 minutes ago, Honda guy Casey said: My 2002 Honda Accord 2.3 EX has a code of P1381. It has intermittent loss to the CMP sensor when it reaches 3000 RPMs after it has fully warmed up. when I let off the gas, it allows the vehicle to shift and drives fine otherwise. I have replaced the distributor and spark plugs and alternator voltages good. Quote Link to comment Share on other sites More sharing options...
Honda guy Casey Posted December 25, 2023 Author Share Posted December 25, 2023 Additionally I’ve replaced the spark plugs distributor and alternator tests good all while fully warmed up. Has code of p1381 cmp sensor intermittent ineruption(at 3000 rpm). I can’t even seem to locate the camshaft sensor only the crankshaft sensor Quote Link to comment Share on other sites More sharing options...
