bilbrelb Posted October 8 Share Posted October 8 Only leaks when running. Coming from right above drivers side Axel where it goes into the transmission. Looking right above there, it appears to me there might be a crack in the block right close to where the lower transmission bolt is but it's a strange place for a crack. Can someone review the bad pic I managed to get and let me know there thoughts? The oil which is pretty new, looks like it's coming out a bit in front of the crack you can see. So not sure if that is an imperfection in the block or a real crack. But I don't think there is anything that goes together close to there that would be leaking from a gasket issue? https://1drv.ms/i/s!AmugQxubsrUviBMhaXnOGFKWjMGP?e=ULRJ6K https://1drv.ms/i/s!AmugQxubsrUviBKaKrh9xVA45GdT?e=8Hbjsc Quote Link to comment Share on other sites More sharing options...
bilbrelb Posted November 20 Author Share Posted November 20 This turned out to be the common vtec solenoid gaskets against the block. It was just dripping down to the spot in the photos. Replaced them and leak stopped. Quote Link to comment Share on other sites More sharing options...
